couple questions: High oil pressure/ MSD6al q's
First: I recently installed a MSD 6al box and blaster coil. The car runs much better down low, the only problem being that it take a second or two longer
for the car to start at cold crank. when it does start it bust off hard/ good,
just taked longer with the MSD hooked up. With is unhooked it bust right off,
I mean with just a bump of the ignition.
Opti is new acdelco with less than 5000miles. plugs gaped at 45
second: My car is a 93 Z with 123K miles on the original engine. The engine
showes 80 psi oil pressure on cold start and dropps to about 60 psi
at full operating temp with a 160 thermostat. With any amount of throttle
it jumps back up to 80 PSI. Over 80psi at wot. IS this normal or should I have
any reason to worry about this? Mechanical gauge showes the same.
Mobil 10-30 synthetic used with a wix filter.
thanks for any help!
Josh.
Josh.
