A/C Questions
Old 10-20-2008, 04:41 PM
cooljoe57's Avatar
Default A/C Questions
To start out, I'm installing a 2002 5.3l engine into my 1980 Camaro, using custom made motor brackets. Now i can notch the frame to get the a/c in (using the original mounting location of the engine) but there is a plug (sensor I'm guessing) on the rear of the compressor that just barely clears my motor mounts but when the wires are plugged in it will hit the mounts.
Now my question is, what is the plug on the back of the compressor and do i need it? If i do need it can it be removed and replaced with a different plug?
Old 10-21-2008, 11:27 AM
Oscar Will's Avatar
That plug is for the A/C high pressure switch. You would need this if running a factory type control circuit. It sends a signal to the PCM to help run the compressor.
I don't think you will find anything to stick in the compressor except that particular switch but if you are using some other type of compressor control you might be able to just leave it unplugged.
Old 10-21-2008, 02:28 PM
fast400's Avatar
You can actually plug it with the right size bolt. You can place the sensor on the high side line to the compressor using something similar to the picture (couldn't find the exact pic)
Attached Thumbnails A/C Questions-ac-fitting.jpg
Old 10-21-2008, 02:52 PM
Bo185's Avatar
You might try using another manifold, bolts to the compressor, off a later truck. I think they moved the switch more to the rear. Can't find any pictures.
Old 10-21-2008, 03:21 PM
fast400's Avatar
I actually have a new Truck compressor I won't be using in my swap. I'll take a look at it tomorrow.
Bob
Old 10-21-2008, 06:55 PM
cooljoe57's Avatar
So if that is the high pressure sensor then as long as i have another sensor in the high side line then i can leave that one alone? If thats the case that will work the best, assuming i can find a sensor bung to weld on the line.
Old 10-22-2008, 12:45 AM
fast400's Avatar
Yup! Make sure that it is the high pressure switch though
Old 10-22-2008, 09:13 AM
01WS6/tamu's Avatar
If you flash the pcm for an 00-02 camaro then have the tuner overlay the spark and fuel tables for the 5.3 over the existing 5.7 tables then you can do the following. The trucks use a system of low and high pressure switches that when wiring a conversion up can be a pain just because of the added wiring. However all of the camaros use a single three wire pressure switch that mounts on the liquid line between the condensor and the evaporator. This single switch controls high and low pressure cut in and out in a neat package that only requires three wires run to the pcm and the a/c request signal to the pcm. If you are running electric fans the f-body programming also has a high and low speed fan output that will automatically engage the fans on a request for the a.c compressor clutch. They make plugs that you can put into the switch port after you remove the high pressure switch.
Old 10-22-2008, 10:25 AM
cooljoe57's Avatar
Ok that seems like a much easier way to wire up the a/c. Just to make sure where all on the same page i got a picture of the a/c compressor. The back plug, so that is the high side?
A/C Questions-ac-compressor.jpg
Old 10-22-2008, 02:44 PM
01WS6/tamu's Avatar
Thats her.
Old 10-22-2008, 03:44 PM
cooljoe57's Avatar
Alright, so now to just find a a/c line or camaro switch to weld into my line.
Old 10-22-2008, 06:13 PM
dsrour's Avatar
you can get the pressure switch port from doc's blocks.
http://www.docsblocks.com/proddetail.asp?prod=AC0146
Have welded on to high side line.
Quick Reply: A/C Questions
