3 bar map??
3 bar map??
were can i get one what all goes into hooking one up and does anyone have a part number?
thanks Ricky
also were can i get a 02 senor for my aem wideban that does not cost a lot?
thanks Ricky
Ricky...this is an easy one
http://www.fuelairspark.com/Products...individual.asp
For hooking it up you gotta run a hose from your intake to the MAP because most of them do not just hook into the back of the intake. Then hook up the wires..Speed Inc sells a harness and they also carry the FAST sensor.
As far as the sensor for the wideband i would check with AEM directly. Didnt you just get that wideband? Sensor already going out?
Here is a link to the GM sensor(s) and adapter harnesses that allow them to be plugged into the factory harness: http://www.lsxtune.com/shop/index.php/cPath/129_143
It's interesting to note that Bigstuff3 uses the same sensor...
