Worth it to ceramic coat exhaust housing?
Old 10-21-2008, 10:44 AM
veee8's Avatar
Default Worth it to ceramic coat exhaust housing?
I was thinking about sending the crappy looking exhaust housing off to get high temp coated. What do you guys think? Is it worth it? Or should I just get the T6 turbo blanket? I was thinking mostly for aesthetic reasons, but I am sure it would improve the thermal efficiency of the turbo.
What all is involved with tearing one of these apart? GT47-88 T6
Old 10-21-2008, 11:09 AM
MECHAM's Avatar
i dunno..
when i got my ST80 it had a gun metal coating and I got it a blankie
Old 10-21-2008, 11:24 AM
Shawn @ VA Speed's Avatar
i like the coated turbine housings,did the ones on my car,it does a the spool slightly,there is just one v band clamp that hold the turbing housing to the bearing housing on the gt4788,just loosen it up and the housing will slide right off
Old 10-21-2008, 11:49 AM
veee8's Avatar
Who should I send it to for coating?
Old 10-21-2008, 10:48 PM
Sideways240sx's Avatar
You can see mine. I did it partly for looks, and partly to help with spool up. The more heat you can keep in the turbo the quicker it will spool up. I also did the exhuast manifolds.
Im considering throwing a turbo blanket over it also.
Chris
Old 10-21-2008, 10:52 PM
Im pretty sure your turbo is similiar to mine. But as said, its a 11 mm nut on the vband. Pop that off, the exhaust housing will pop right off. You can do the same thing to the charge side, i had mine powder coated black since its alum, and cant be done in ceramic.
I wanted the center section painted somehow, but i was told if taken apart, it all has to go back to pte to get rebalanced, and might get costly. So i left it how it was.
Chris
Old 10-22-2008, 06:33 AM
veee8's Avatar
I like the aluminum finish on the compressor side,
I was thinking of having the turbine side in a nice shiny silver ceramic, who should I send it too, I had Jet Hot headers on the LT4, and they rusted after a year, I used HTC years ago, and the finish was a bit dull. Any suggestions and prices?
Old 10-22-2008, 09:44 AM
mike13's Avatar
performance coating in Auburn WA does a great job and has quick turn around. If you google them they have a website with prices and products.
Old 10-22-2008, 05:40 PM
When i had my motorcylce i used jet hot. I really thought they were great, for header and pipe in flat black.
My turbo stuff was done by a local guys thats not a sponser. I dont know if you would want to ship your stuff out here, but i can get you in contact with someone if you want.
What about fx coatings? they were a sponser, but i tried to go to there website, and its gone? i know frcfed98 used them.
Ps the guy that did my ceramic, also did my powder.
Chris
Old 10-22-2008, 05:55 PM
chewy99ws6's Avatar
I had mine done when I ordered my turbo, the whole hotside is coated, I can beat on it all day amd when I am done I can still touch the intake side of the turbo, it was worth every penny, that is my $.02
Old 10-23-2008, 06:37 AM
veee8's Avatar
That is what I was thinking. Do you know who did the coating?
Old 10-23-2008, 08:54 AM
chewy99ws6's Avatar
Jet-Hot did the coating.
Old 10-23-2008, 01:18 PM
Johnv's Avatar
Coating looks good and does reduce temps, but nowhere near as much as a beanie. I've had both and prefer the beanie
Old 10-23-2008, 02:04 PM
LS1TECH Sponsor
DrTurbo's Avatar
Blanket is the most effective way.
Quick Reply: Worth it to ceramic coat exhaust housing?
