Upcoming Turbo Build Questions.
Old 10-21-2008, 01:29 PM
1fastTransAm's Avatar
Location: Chitown-Jax NC-Jax FL-Honolulu-OKC, OK-NOW New Orleans Area
Default Upcoming Turbo Build Questions.
I am strongley considering doing a Turbo build on my 408 but not to certain about a few things and dont want the motor to go pop on my. I dont know all the details about the motor since I bought it from FFHP and never got a flow sheat and they went under. What I do know is that the car was built for TONS of Spray, running 11-1 comp. Has the TexasSpeed Giant cam in it, Patriot Stg 2 317s heads, Long tube headers, I have a AEM Wideband and for everything else just look at my sig..
I am about to get this:Garret 76mm Turbo compressor wheel
.55 A/R compressor housing
.96 A/R turbine housing
Journal, t4 flange.
Its brand new.
What I THINK I know I need.
1- Different heads but which ones
2- New intake?
3- Maybe new fuel rails depending on the intake
4- 60lb fuel injectors
5- Truck manifolds
6- blow down piping
7- blow off vlv
8- boost gage
9- Relocate battery to rear
10- Boost controller
11- thicker head gaskets to help lower comp. ratio
12- A second Fuel pump
Also how much boost is possible without blowing the motor?
I also am going to be replacing the fuel lines from front to rear so more fuel can flow.
I have incl. a pix of the engine bay to help show what is there and isnt.
I also have a built 6speed trans, stock 10bolt FOR NOW, getting a 9in in the spring.
Old 10-21-2008, 10:26 PM
Anyone???
Old 10-21-2008, 10:54 PM
headed-ws6's Avatar
Get a new cam. Lower the CR as much as possible. Intake is fine. Need to relocate alternator. battery doesnt need to be moved unless you plan on putting the turbo there.
Old 10-22-2008, 01:27 AM
ModularTurbo's Avatar
Gimme a call bud. I can help you out.
Old 10-22-2008, 09:57 AM
cool thanx. calln now
