Staff Vehicles Showcase - dlove's 414 Powered 00 z28
dlove
10-21-2008, 03:01 PM
2000 Chevrolet Camaro Z28
White
~110k Miles
Sponsors:
All out of pocket and in my garage.
Factory options:
A4, Hard Top, Leather, All Power Options
Engine:
LS3 shortblock with katech rod bolts ~4k miles
Stock Port L92's, .040 Gasket. Patriot Extreme springs.
My own ported l76 intake / NW 92mm TB.
LG G6x3 cam
SLP 1 3/4 headers, 12'' turn downs off the headers
No Thermostat
ASP Crank Underdrive Pulley
NGK TR6 Spark Plugs, MSD Plug Wires
Full EFI Live SD tune. Tuned by myself.
Transmission:
Powerglide transmission, built myself.
Circle D- 5C 5000 stall
BMR crossmember
Stock steel Driveshaft
Rear End:
Strange 12 bolt, 4.11's, spool
Suspension / Brakes:
Custom Welded Subframe Connectors
Custom chromoly 6 point
QA1 R's with Afco 275 springs in front
Profab K member
Madman 1 off solid motor mounts
Madman manule rack
Burkhart 2'' drop spindles
Strange double adjustable rear shocks with v6 springs
SJM Tubular Lower Control Arms with Welded in Relocation Brackets
Madman Torque Arm
Strange Manule Master Cylinder
Strange front and rear brakes
Appearance:
Harwood black lift off SS hood.
Greg Weld front wheels with ET fronts
Rear Summit ProStarts with lots of different tire combos lol
Smoked headlights and corners
RCI plastic seats
Lightweight carpet
Harlen shiftlight in center vent
B&M Pro ratchet shifter
Grant steering wheel
Planned Future Modifications:
Upgrade Headers
Performance Statistics:
N/A best with the LS2.
1/4 Mile: 10.46 @ 128, 1.47 60ft
About This Car:
Pretty much a drag only car that I drive on the street more than the track.
Race weight is 2800 with me in it.
dlove
10-26-2008, 09:16 PM
cage
http://i125.photobucket.com/albums/p41/azxic/037.jpg
dlove
10-28-2008, 12:15 AM
some vids
my car NA with the ls2 vs a 10.6-10.8 truck
http://www.youtube.com/watch?v=PfvDDd7Cd_o
some old n/a runs, car was anti squating hard
http://www.youtube.com/watch?v=gWvHNcicv9Y
fastest pass to date, first day the tracked opened for the season, was not holding anything
http://www.youtube.com/watch?v=4TsTDz-a1wI
dlove
10-30-2008, 12:33 AM
some new pics (thanks frito1)
http://i125.photobucket.com/albums/p41/azxic/IMG_1963.jpg
http://i125.photobucket.com/albums/p41/azxic/IMG_1964.jpg
http://i125.photobucket.com/albums/p41/azxic/IMG_1965.jpg
http://i125.photobucket.com/albums/p41/azxic/IMG_1971.jpg
http://i125.photobucket.com/albums/p41/azxic/IMG_1973.jpg
dlove
10-30-2008, 12:34 AM
new N/A best tonight as well
10.46 @ 128 with a 1.47 60'
dlove
11-10-2008, 09:26 PM
some new pics. bigger rear tires are waiting to go on, as well as lower the rear. all the dust is from it being in a cave
http://img.photobucket.com/albums/v74/four_under/IMG_0190.jpg
http://img.photobucket.com/albums/v74/four_under/IMG_0261.jpg
http://img.photobucket.com/albums/v74/four_under/IMG_0260.jpg
http://img.photobucket.com/albums/v74/four_under/IMG_0243.jpg
http://img.photobucket.com/albums/v74/four_under/IMG_0194.jpg
http://img.photobucket.com/albums/v74/four_under/IMG_0130.jpg
dlove
11-27-2008, 07:57 PM
sold the LS2.
LS3 soon...
dlove
11-30-2008, 05:19 PM
http://i125.photobucket.com/albums/p41/azxic/IMAGE_416-1.jpg
http://i125.photobucket.com/albums/p41/azxic/IMAGE_414-1.jpg
dlove
12-03-2008, 04:02 PM
Heads are just getting milled, and put on unported.
cam is the g6x3
dlove
12-20-2008, 08:25 PM
It runs :devil:
dlove
12-22-2008, 09:58 PM
Pretty much how she will look. Need to clean up a few things here and there though.
http://i125.photobucket.com/albums/p41/azxic/IMAGE_013.jpg
http://i125.photobucket.com/albums/p41/azxic/IMAGE_015.jpg
http://i125.photobucket.com/albums/p41/azxic/IMAGE_017.jpg
dlove
12-30-2008, 10:30 PM
newer pics. added a few things.
dlove
01-03-2009, 10:32 PM
few new pics
http://i125.photobucket.com/albums/p41/azxic/IMAGE_018.jpg
http://i125.photobucket.com/albums/p41/azxic/IMAGE_019.jpg
http://i125.photobucket.com/albums/p41/azxic/IMAGE_020.jpg
http://i125.photobucket.com/albums/p41/azxic/IMAGE_022.jpg
http://i125.photobucket.com/albums/p41/azxic/IMAGE_025.jpg
http://i125.photobucket.com/albums/p41/azxic/IMAGE_028.jpg
dlove
02-11-2009, 07:20 PM
Some of my new parts got here today
MADMAN Torque Arm and Manual Rack
http://i125.photobucket.com/albums/p41/azxic/IMAGE_038.jpg
dlove
02-18-2009, 08:55 PM
More parts came in.
http://i125.photobucket.com/albums/p41/azxic/gregwelds1.jpg
http://i125.photobucket.com/albums/p41/azxic/15x10.jpg
For the front.
http://i125.photobucket.com/albums/p41/azxic/feelinalittlestrange.jpg
Double adjustables for the rear
http://i125.photobucket.com/albums/p41/azxic/IMAGE_050.jpg
dlove
02-21-2009, 04:29 PM
http://i125.photobucket.com/albums/p41/azxic/1235254956.jpg
dlove
03-04-2009, 11:57 PM
http://i125.photobucket.com/albums/p41/azxic/1236230456.jpg
Strange 12 bolt w/ strange brakes
Narrowed 3'' per side
spool, 4.11's
lightweight yoke
lightweight axle ends
Aluminum cover
The weight with fluid is...... 180lbs
My stock 10bolt with auburn limited slip and stock brakes:
205lbs
dlove
03-15-2009, 12:14 AM
http://i125.photobucket.com/albums/p41/azxic/011-1.jpg
http://i125.photobucket.com/albums/p41/azxic/012-1.jpg
http://i125.photobucket.com/albums/p41/azxic/013-2.jpg
This came out of the intake
http://i125.photobucket.com/albums/p41/azxic/014-2.jpg
http://i125.photobucket.com/albums/p41/azxic/015-1.jpg
http://i125.photobucket.com/albums/p41/azxic/018.jpg
dlove
03-24-2009, 12:04 AM
I found what did my motor in. The vvt oil pump.
Found a spun bearing in the bad cylinder. Looks like I probably sucked the pan dry.
The extra slop in the rod cause it to come up more in the cylinder and hit the valve.
Total damage:
1 broken in half valve
1 busted lifter, all the rest apear worn
3 bent valves
1 missing piston
1 piston broken off the rod
2 bent rods
1 spun bearning
2 cylinder sleeves with lots of chunks missing
cracked block
camshaft scored on a few lobes
both heads need lots of work
windage tray bent
Crank scored up
Oil pump burnt up
dlove
05-18-2009, 11:21 PM
http://i125.photobucket.com/albums/p41/azxic/1242699158.jpg
http://i125.photobucket.com/albums/p41/azxic/1242698178.jpg
http://i125.photobucket.com/albums/p41/azxic/1242698379.jpg
http://i125.photobucket.com/albums/p41/azxic/1242698551.jpg
Need to pull the trim off the door and work on getting the fenders lined up.
I also have an SS wing on the way!
jhelms
06-17-2009, 08:31 AM
Looking good, any updates?
dlove
06-17-2009, 09:52 AM
Ordered some parts to refresh my glide, all it needed was a new band. I hope to have the motor back in by next weekend.
dlove
06-25-2009, 11:40 PM
http://i125.photobucket.com/albums/p41/azxic/IMAGE_054.jpg
http://i125.photobucket.com/albums/p41/azxic/IMAGE_055.jpg
dlove
10-11-2009, 09:20 PM
Car is SOLD
I will do a history write up on it soon.
