Stereo & Electronics - E30 Error Code CD Changer?
02RedWS6RamAir
10-21-2008, 03:21 PM
So my 95 Trans Am has a tape deck and the 12 CD Changer in the trunk. It would have been nice if the CD changer worked but it doesn't. I put a CD in and all I get is a display of E30. I'm sure it's some sort of error code. Any ideas? Thanks in advance.
WhiteBird00
10-21-2008, 03:54 PM
You probably have the discs in the wrong way. The GM changer takes the discs label side down unlike almost every other changer ever made.
02RedWS6RamAir
10-21-2008, 04:00 PM
I didn't know that!
I'll check it out later this evening!! Thanks! :)
The Errors Codes are listed in the Monsoon FAQ at the top of this section.
Here is a link to the Monsoon FAQ:
http://www.ls1tech.com/forums/showthread.php?t=612644
02RedWS6RamAir
10-22-2008, 01:39 AM
You were right, that's exactly what I did! It would never have occurred to me that they needed to be loaded label side down.
Anyway, thanks again! I was ready to buy a new stereo for my bird!
2000pontiacws6
01-24-2010, 07:02 PM
I had the same problem, i thought it was just because they were burned CD's but we had put them in label side up, burned CD's will work with the 12 disc CD changer
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
