New 'Billet Valve Cover' range for LS engines
Hi guys,
We have developed a range of Billet Aluminum Valve covers to suit most variants of the LS engine, ranging from a stock replacement type that has a factory style breather and integrated coil pack mounts, to our ‘Racer’ type cover that have no coil pack mounts for a very smooth look, and are taller than the factory covers to accommodate most aftermarket rocker gear. You can also get the tall version with the coil pack mounts built in. All of the LS series covers also have extra material at both ends to accomodate larger fittings for catch tank systems.
Also we have designed and produced some little ‘Bling’ Billet aluminum coil pack covers to hide the factory (and aftermarket MSD) coil packs.
On top of our LS engine range of products we also make Billet Valve Covers to suit most popular (and some not so popular) V8 engines.
A full list of our valve covers is available on our website.
www.noonanraceengineering.com.au
And finally here are a few photos to give you a better idea of our products;
Standard height L98/LS2 with optional coil pack covers
Tall Height LS1 with optional coil pack covers
Tall Height L98/LS2
Tall Racer
Please visit www.noonanraceengineering.com.au for more information
Tall Height L98/LS2
Tall Racer
PRI Show
Just a quick note to let you all know that Noonan Race Engineering will be at the 2008 Performance Racing Industry (PRI) trade show!
Come and see us at booth 3223 for a good, up close look at our Billet Valve Cover range.
We will also have on display some of our engine components from the Australian V8 Supercar Series as well as our Brand new Billet HEMI cylinder head for top alcohol drag engines!
Check out our booth location at the PRI website
http://perrace08.mapyourshow.com/2_1...markcamefrom=y
Thanks everybody
Joel
Thanks everybody
Joel
Polished Valve Covers!
Recently we decided to try a little experiment and sent one of our valve covers out to be polished. Due to the ballnose machine finish we always thought they probably would not look much different. As it turns out we were wrong!
Polished LSx Series Racer
Polished LSx Series Racer with as-machined SB Chev Lightweight cover in the background
We don’t currently offer polishing as an option when ordering our valve covers but if there is much interest shown we will definitely add it!
Cheers everybody,
Joel
Cheers everybody,
Joel
