Budget build (advice needed)
Old 10-22-2008, 10:02 AM
dubrado's Avatar
Default Budget build (advice needed)
I was going to tear down the stock motor, throw in some forged pistons and spray a 200-250 shot. that is the plan and goal
I was wondering if just changing out the pistons/rings and putting in ARP rod bolts would be enough. I don't know if I necessarily need H beam rods. I was hoping stock rods would hold. I don't expect to spin the motor to anything to extreme, high 6000's or maybe just tap 7000rpm.
Old 10-22-2008, 10:12 AM
z28rob18's Avatar
wat motor?
Old 10-22-2008, 10:26 AM
Cliff's Avatar
Your going to need ARP head studs, better then stock gasket and a very good tune for 200-250. I would think a direct port kit would be a good idea with a 250.
Old 10-22-2008, 11:51 AM
dubrado's Avatar
I have ARP head bolts right now. Also have a decent gasket.
I have a plate for the kit right now
It's an LS1 in a GTO
what about stock rods though, are they strong enough for a big shot like that? I read that the bolts are weak but what about the rods themselves?
Old 10-22-2008, 11:55 AM
8 second mod
Noyzee's Avatar
the rods are ok, but for 100 bucks you can get bolt or add another 300 and get some eagle rods with arp bolts already in them, a set of pistions and your good to go, no questions asked.
Old 10-22-2008, 12:03 PM
BOTTLEFEDLS1Z's Avatar
A stock MLS gasket will do just fine for this. No need to spend extra money if this is a budget.
A head gasket issue is a "tuning" issue. Usually to much timing......
Old 10-22-2008, 12:08 PM
allmotor's Avatar
I'm going to be spraying 200 direct port on stock bottom LS1, but I know it will be fine because I have a dedicated race gas fuel system for the nitrous.
At least get the rod bolts. You could drop more money for eagle rods, but you'll be fine with stock rods..but 300 for rods w/ bolts is a pretty good deal...
Old 10-22-2008, 04:12 PM
dubrado's Avatar
where are you getting rods and bolts for 300 bucks?
Old 10-22-2008, 04:28 PM
allmotor's Avatar
http://www.sdpc2000.com/catalog/lsge...ctingRods.aspx
Those arent the eagles, but same price.
