couple o-ring questions
im changing my timing chain next weekend and i have a couple questions about the oil pump o ring
1) is a good idea to replace it or reuse the old one
2) does it have to be a gm part o-ring or will any rubber o-ring work (what size is it)
3) anyone have a gm part number for it
4) is using two a good idea (saw the other thread on here)
any tips
thanks
ryan
any tips
thanks
ryan
Re: couple o-ring questions
1) REPLACE IT!
2) Why gamble? How did you plan to size it, by eyeballing?
3) 12557075 (costs around $4.00)
4) No.
TIPS:
- Bolt the pickup to the pump BEFORE you bolt the pump to the block
- Make sure the you get the old o-ring out so you don't accidentally install both.
4) No.
TIPS:
SN95 Director
replace it , i ordered mine last week, ****** expensive though :dammit:
Order Detail
Order Detail:
Quantity
PART NO.
DESCRIPTION
PRICE
EXT. PRICE
CORE
TOTAL
STATUS
Tracking #
1
*12557752
SEAL
$1.94
$9.70
$0.00
$9.70
In Process
Taxes:
$0.00
Handling and Shipping:
$7.95
ORDER TOTAL:
$17.65
* indicates special order items, which are not returnable for refunds.
Order Detail
Order Detail:
Quantity
PART NO.
DESCRIPTION
PRICE
EXT. PRICE
CORE
TOTAL
STATUS
Tracking #
1
*12557752
SEAL
$1.94
$9.70
$0.00
$9.70
In Process
Taxes:
$0.00
$7.95
ORDER TOTAL:
$17.65
Do not take chances here - a real PITA if you screw up!
Change to a new o-ring - $5 at my dealer... your dealer will have these in stock...
Follow JMX's instructions -
Also, replace the o-ring and bolt up the pick-up tube BEFORE you bolt the pump to the block - this prevents you from pinching the o-ring...this is especially important if you are going with a double roller timing chain...
place a rag between the pick-up tube and the pan so if you drop the pick up tube bolt it does not go into the bottom of the oil pan...
You can try two o-rings there should be plenty of space on the tube; I'm not sure if anyone has tried this yet, however...
