BMR Pinoion Angle?
Old 10-22-2008, 09:22 PM
never2low's Avatar
Default BMR Pinoion Angle?
So After about 100 miles after installing my new adj BMR T/A according to the BMR instructions and vid, my rear u-joint exploded without any signs of wear or noise. When it let go it smashed up my exhaust and T/A both beyond repair. I'm wondering if the wrong pinion angle according to this, https://ls1tech.com/forums/suspension-brakes/974198-measuring-pinion-angle.html, would cause the u-joint to fail, or if its just part failure. I'm just curious why it would explode after just installing the T/A and installing it according to their specs? I planned on using all BMR products on my car this winter, but if thier products cause other part failure, I'm not sure I want to use them again. Any input is appreciated.
Old 10-22-2008, 10:22 PM
Restricted User
socmguy's Avatar
Did you have it setup at -2*? If it was right at 0 it could definitely cause premature failure of the U joint. Sorry about all your hassle, hope everything works out.
Old 10-22-2008, 10:35 PM
never2low's Avatar
We set at -3 according to thier recommendation for an m6.
Old 10-23-2008, 12:38 AM
danhr's Avatar
pics of u-joint would be helpful
Old 10-23-2008, 04:24 PM
BMR Tech's Avatar
Give me a call here at the office. A -3 degree pinion angle will not cause a u-joint failure unless the u-joint was already on it's way out
Old 10-23-2008, 05:16 PM
2FAST4U's Avatar
I have tons of broken parts but never a pinoion. Is the driveshaft stock? I have mine at -2* Should be -3* but haven't got back uder there.
BMR is some of the best product available. I have all of it.
