Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
please help! brake issue
Old 10-23-2008, 09:06 AM
z28rob18's Avatar
Default please help! brake issue
ok i drove the car home last night everything fine. woke up this morning went to back out and go to work and i had zero brake pressure. look at fluid level empty filled it and had a bit of pressure drove to work and its has barely any brake pressure i c no leaks anywhere the hoses upfront r fine help im stumped?
Old 10-23-2008, 09:12 AM
02BEAST's Avatar
Might need to be bled sounds like you might of sucked air in the lines if the fluid was empty.
Old 10-23-2008, 09:17 AM
BUSA01's Avatar
Master Cylinder bleeding back into the powerbooster, front to rear brake line or a caliper could be leaking. Just a few things I'd look at
Old 10-23-2008, 09:24 AM
z28rob18's Avatar
alright i cant c much on the ground at work but everything i can c looks fine how would i hav got air in the lines lik that?
Old 10-23-2008, 09:30 AM
02BEAST's Avatar
If you say the brake fluid was empty that would suck air in the lines when pressing the pedal.
Old 10-23-2008, 09:45 AM
z28rob18's Avatar
ok i understand that but the brake fluid wasnt empty yesterday and there was still a little bit in the bottum. but it doesnt feel lik air bubble in the line the peddle just goes straight to the floor. ill take ur advice into consideration for later wen i look at it though.
Old 10-23-2008, 09:48 AM
02BEAST's Avatar
Check all your rubber lines may be cracked somewhere and sucking air.
