First 1/4 run w/ 383
Old 10-23-2008, 10:08 AM
tscheu5452's Avatar
Default First 1/4 run w/ 383
Hey LT1 dudes. Just thought I'd post a vid of my run last night. Only one run because of multiple oil spills and hours of clean up. Real happy with the results! Still took a spanking from my buddy's 383 supercharged LS1 though!
Old 10-23-2008, 10:27 AM
James Montigny's Avatar
Nice work get those 60s down a little and you'll be into the mid 11s.
Old 10-23-2008, 10:47 AM
whammer33024's Avatar
[ Real happy with the results! Still took a spanking from my buddy's 383 supercharged LS1 though!
haha, yeah ya did! but nice run either way. car sounds mean
Old 10-23-2008, 10:57 AM
registered user
ScreaminRedZ's Avatar
Very nice! What's you're setup? (heads/cam, etc.)
Sucks about the cleanup time. Some people don't know that when they break it's a bad idea to drive down the whole track anyway.
Old 10-23-2008, 11:06 AM
tscheu5452's Avatar
Cam specs. 234/238 .576/.595 114+4
110 ICL
7* IVO/ 47*IVC
Stock heads maxed out by LPE 2.00 intake--1.56 exhaust. Stock intake ported and polished. 58mm LPE throttle body.
Old 10-23-2008, 11:56 AM
registered user
Very nice. Strong running setup, few more practive passes and you'll be deep 11's! What were you running for tires?
Old 10-23-2008, 12:03 PM
riceburnerZ28's Avatar
a few more practice runs and maybe some better tires then you'll be set !
Old 10-23-2008, 12:04 PM
tscheu5452's Avatar
BFG Drag radials. Stock suspension. Stock rear end.
Old 10-23-2008, 12:26 PM
Stock gears as well?
Is it launching hard or spinning off the line?
What tire pressure are you running?
Old 10-23-2008, 12:28 PM
jwastedx's Avatar
Nice run what H/C combo are you running??
Old 10-23-2008, 02:26 PM
tscheu5452's Avatar
Yes. Stock 3.42s Spun some off the line. 16lbs of pressure. It was very cold. Probably about 40 degrees. Good for power, bad for traction. I also have a Spec stage 3+ clutch that I used for the first time. It is very driveable on the street but it seemed to grab hard all at once on this run. A bit of a learning curve to figure out how to launch with it. This was also my first trip to the strip in two years!
Old 10-23-2008, 02:36 PM
Launching hard with a stick is a good way to blow the stock rear end to bits.
(and be the guy everyone is staring at for having oiled down the track and ruined their night of racing)
It might not be a bad idea to start with a rear end up upgrade before improving traction or weight transfer.
Old 10-23-2008, 02:40 PM
tscheu5452's Avatar
Moser 12 bolt in the spring. Trying to decide on gears since I will be spraying too.
Old 10-23-2008, 03:10 PM
jarretthise's Avatar
hey man i noticed you were at the muncie strip? where you at in indiana?
Old 10-23-2008, 04:14 PM
tscheu5452's Avatar
Yes sir
Old 10-23-2008, 09:38 PM
LS1 SPEED's Avatar
nice results especially for your first outing
