2005 GTO A4 - Cam Only Results 444/409SAE
2005 GTO
TTP 4L65E
TTP Punisher V.4 Cam
TTP Port/Polished FAST 92mm LSx Intake Manifold
TTP Port/Polished 90mm Throttle Body
Patriot Gold Dual Spring Kit
Pacesetter Longtubes, Offroad H-Pipe
K&N Cold Air Intake
Stock Catback Exhaust
SAE Corrected
Uncorrected
We are having specials all the time on our cam only installations on Y-Bodies, F-Bodies, CTS-V's and GTO's. Give us a shout or PM us for further information on our packages.
TTP 4L65E
K&N Cold Air Intake
SAE Corrected
Uncorrected
LOL Chef, that's why I made sure to post the SAE. The uncorrected was too good not to post haha.
Kerminator has gone through some changes recently. We're going back over to a hydraulic roller with aluminum rods. We're going to keep the combo under wraps for a bit but we'll be looking for some NA h/r records soon..
Self-Admitted Scammer
Yum...thats a good amount of power. What does your shop charge to do all of these (parts + labor):
K&N Cold Air Intake
Just as an example...i am trying to decide if i should trade in to a 06 vette or get another 06 GTO and go crazy with it.
K&N Cold Air Intake
Their last cam speical: https://ls1tech.com/forums/showthrea...646&highlight=
You can't beat that price
This is not the same cam profile as the ones I have been using with the Trick Flows. This is our original Punisher V.4 cam profile based on Comp XE-R lobes.
3600 Vigilante Converter.
Our cam special is a little different on pricing now I will re announce them:
- TTP Custom Camshaft
- Patriot Gold Dual Spring Kit
- Trick Flow Hardened C/M Pushrods
- GM OEM Gasket/Bolt Installation Kit
- LS2 HD Timing Chain
- Full Professional Installation
- Full Custom Dyno Tune Including WOT and Part Throttle Tuning
FBody, GTO, CTS-V $1850 (-$75 if LS2 Timing Chain equipped 05-06)
C5 or C6 $2100 (-$75 if LS2 Timing Chain equipped 05-06, Add $50 for LS7 timing sprocket for 07-08 Single Bolt Cams)
You can check out some of the graphs at www.ttperformance.net/Gallery/
