new tires causing abs / tcs inop?
Old 10-24-2008, 06:32 PM
Adam1982's Avatar
Default new tires causing abs / tcs inop?
fronts are 275/35/18, rears are 295/35/18 nitto invos. I know several people running this set up and they have no problem with their abs inop and tcs light. I know dfferent tire sizes can cause this problem, but it only happens on highway driving so i dont think its the tire size that is the problem. Any idea? Wheel speed sensor?
Old 10-25-2008, 11:52 AM
Xsta Z 28's Avatar
Sorry to hear . . . I do not understand why . . . I run those very same tire sizes with no issues . . .
Old 10-27-2008, 10:54 PM
Adam1982's Avatar
bump..
Old 10-27-2008, 11:24 PM
2K2WS6TA's Avatar
As long as the tire diameters are the same as the OEM, or not more that a certain percentage difference from each other, the ABS/TCS doesn't care what size is on the sidewall
Sounds like a speed sensor has gone bad or isn't getting a correct signal, check the wires and connectors first
