Drag Racing Tech - front sway bar removal?
z28rob18
10-24-2008, 06:57 PM
ok i knew this would be a popular topic so i searched it and had some questions answered. i saw that it only helps at the track wit the right shocks does that mean front or rear shocks? is this something that will help alot with hooking up and weight transfer with DRs and spraying off the line? and most of all is it safe to drive the car without the sway bar to the track and home from the track and nowheres else?
CamaroRacing12
10-24-2008, 07:17 PM
yes it helps no matter what... and u will be completley fine if ur driving it to and from the track...
James Montigny
10-24-2008, 07:40 PM
I pull it for good race season weather and put it back when I am done,
Typically a few weeks in the spring then a few in the fall.
It handles ok on the street without, but you can definitely tell it's gone.
Then again, I run a huge, heavy Spohn front swaybar.
It helps get weight transferred to the rear and it's a decent weight reduction mod.
OIF1VET
10-25-2008, 03:55 AM
Mine hasn't been on in 3 years.. No issues here on the street. But I only drive mine a couple K each year and hit the track 2-3 times a year..
Randy WS6
10-25-2008, 07:51 AM
Mines been off for two years now , No problems at all. Grate weight transfer.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
