biggest shot on a STOCK ls1 ?
Old 10-24-2008, 07:22 PM
fastburn's Avatar
Default biggest shot on a STOCK ls1 ?
curious what guys have been doing.whats the biggest shot a stock ls1 can handle without have problems with the rotating asembly?
Old 10-24-2008, 07:24 PM
philsblwnz28's Avatar
I have heard 150 shot, but thats just what a buddy told me......
Old 10-24-2008, 07:33 PM
MYSTIC-1SC's Avatar
i have seen plenty of stock bottom end ls1s sprayed with a 200 shot last for a long while with the proper tuning.
Old 10-24-2008, 07:46 PM
showoff's Avatar
iam currently spraying a 200hit, stock bottem end with a ms3 cam..the motor loves it
Old 10-24-2008, 08:50 PM
SuperSlow02's Avatar
depends on the car and tune. Some have come apart with 100. Hell I think some of the LS6 guys are past 200.
Old 10-25-2008, 09:49 AM
Lythropus's Avatar
Lots of people run 300 hits in two stages on stock motors, two people here off the top of my head have done it. One motor lasted two years and then threw a rod, the other laster about a year before a ring failure...
My first TA had 225 in two stages and it lasted 3 years until a caddy ran a red light...
Old 10-25-2008, 03:11 PM
LS1Z28-00's Avatar
yep ive heard of 300+ shots. ive seen several take 200 shots like nothing. it just depends on how healthy the motor is and if you have all the supporting mods for the shot your doing.
Old 10-25-2008, 03:41 PM
FiredUpZ28's Avatar
Originally Posted by showoff
with a ms3 cam..
Old 10-25-2008, 04:21 PM
omore001's Avatar
On my old 2002 M6, 150 NX wet with intake and exhaust, lasted about 50 passes before a backfire cracked the plastic LS6 intake manifold. After installing the Weiand Aluminum manifold. ran another 50 passes before getting piston slap. My advice, if its stock and you cant afford F.I. keep it under a 125 shot and make sure its wet and at the very least, make a pass on the dyno with the juice keeping a close eye on the Air/Fuel to make sure your not running lean.
Old 10-25-2008, 04:22 PM
b00sted's Avatar
I've personally done 225 a couple years ago. Stock motor with a decent tune and 7-8 degrees pulled. 100 Octane VP fuel.
Old 10-25-2008, 07:35 PM
98childsta's Avatar
If you are talking completely stock, with no tune I wouldnt go any higher than 125 my buddy had a stock 99 camaro with only 52K, we went to the track we started off with a 75shot he ran 13.20, wanted 12's so we changed to a 100 shot 12.70's he wanted to do low 12's so we went to a 125 12.20, he got greedy and wanted high 11's so he put a 150 (this is all wet shots of course)............He ran a 14.80 and luckly we had a trailer cause with no wide band, no tune, just a stock ls1 6spd the #7,and 5 piston had a hole in it when we pulled it apart the following day. But we had a good battle...
Old 10-26-2008, 06:32 PM
Mike 02T/A's Avatar
Still running a 150 shot here.
Old 10-26-2008, 06:51 PM
RedRallyeZ's Avatar
How much can the stock bottom end handle? explained...
imagine that, a sticky!!!
Old 10-28-2008, 04:17 PM
rpmotorsports07's Avatar
We sprayed 300+ dry almost every weekend on a stock 6.0. Completely stock internals with fuel pumps, injectors and tuned. Never hurt it. So it CAN be done. You have to find a good tuner that is willing to work with you on it.
Old 10-28-2008, 08:41 PM
JDP
JDP's Avatar
****, dont be a little girly and stop at 125, just make sure you have the proper safety stuff and a wideband and give it hell. i didnt have a wideband or a fpss and i chipped #7 with a 150 shot cause my pump didnt keep up.
just start out with a small shot and work your way up and make sure everything is right. there are a ton of people that hit their bottom end with a big shot
Old 10-31-2008, 08:09 PM
Sprayed 99's Avatar
200 hit with 22 degrees timing, pump gas and tr6's. car loves it
Old 10-31-2008, 09:26 PM
Ice78Transam's Avatar
Its kinda Like asking people how much money to bet in vegas. Its up to you. Risk what you want. I have seen some pretty sad cars take mad shots. and like everybody else said LS1's with 2-- shots.
Old 10-31-2008, 09:32 PM
regency's Avatar
i would like to know what a stock motor with stock tune could handle
Old 10-31-2008, 11:01 PM
SlowFRC's Avatar
Dude needed a 100 shot to get into the 12's? Ouch thats painful, although I can't really talk im still in the 13's
Old 11-06-2008, 07:47 PM
KC Henry's Avatar
Not a "stock Bottom End" (Like the sticky). I mean 100% Stock LS1, right on down to the OEM fuel pump and OEM spark plugs (or maybe TR6's).
Quick Reply: biggest shot on a STOCK ls1 ?
