Sub not fitting in stealth...
I just recieved my FiQ10 Subwoofer yesterday, and ive got the Stealth Enclosure from SubThump.
The sub does not fall right in, the sides of the sub. If your familiar with the FiQ10 subs, is rubbing against the enclosure. It's about a half inch gap from the sub being completely flush against the enclosure.
Should i wire the sub up and just force it in there??? It wont damage the sub or anything doing that, or should i try and file down the sides of the enclosure where the sub rubs to fit it right in there??? The sub will fit in there completely, just that its wider then most subs. So its rubbing just a bit.
i used a dremelon my stealth box for my RE SE cause it was way to big for the hole. forcing it down would possibly damage the mdf and i always find some reason to take it out and it would be a PITA to take the sub back out.
yeaa, ill let u guy's know how the FiQ10 sub turns out for me.
I may just do what you suggested 99bluz28. thanks for the help, just wanted to know if this would be a good idea.
