What's the secret to installing PBR piston dust boots
Old 10-26-2008, 04:19 AM
drain89's Avatar
Default What's the secret to installing PBR piston dust boots
I'm re-assembling my calipers after having them powdercoated. I can't get the boots on. What am I doing wrong? I heard it's a simple operation...but I've just spent an hour TRYING to get one boot on. Is there a certain method? I can't get the lip to fit down in the groove, there just isn't enough room. I even tried soaping up the lip and using a small screwdriver to push it in.
Old 10-26-2008, 05:22 AM
Foxxtron's Avatar
http://www.installuniversity.com/ins...er_rebuild.htm
I'm not too sure if you're using this method, however it has always worked for me.
Old 10-29-2008, 08:04 AM
NOBR8KSS's Avatar
I've heard of parts not fitting back together after powdercoating...you may need to shave the powdercoat off in that area.
Quick Reply: What's the secret to installing PBR piston dust boots
