Bumpin redline.
Bumpin redline.
I just bought a 95 camaro, and the previous owner does not know what has been done to the car prior to them owning it. I know it has a 160 themastat, and flowmasters, but not sure about a tune.
Now to the problem. When you get on it the car pulls good to redline, but then it does not want to shift out after it redlines a little it shifts to 2nd, then the same thing happens for 3rd. What can I do to fix this. It seams to be redlining at 5700 or so. What is it from the factory???? Can a mail order tune correct this?
I believe that is factory shift point, trust me, you dont want it to go anyhigher, the car doesnt really pull good up there in rpm.
my shift point is 6000 from the factory, and you can really feel the car lay over once it gets around 5800+ rpm
the trans not shifting is an issue. Don't worry about reving the engine though. My rev limit is set at 6250 on my Accel box and trust me its bounced off that rev limiter more times than I care to remember. It just won't die, 165k on it and it still runs 13 flat. My internally stock LT1 has eaten 2 transmissions and 2 rear ends but still runs like a top.
That graph, I think, proves more that you SHOULD shift around 6-6.2K! The HP slowly drops off and you're still making nice power. If it just dropped like a rock, then I'd say you're absolutely right. It also looks to not be floating either, so all in all, I say bump up that limiter.
