95camaro3800
10-26-2008, 10:03 PM
I'm just putting my motor back in, and I'm hung up with getting the slave back in the tranny. At first, I slid the clutch fork in, but apparently not all the way, so once the slave was bolted in, I pressed the clutch, and it was extremely stiff. I took it apart again, and the fork was sort of lodged in the little casing area. I pulled it back out, and used a screwdriver to pry the clutch fork back into place, it's good and solid in there now.
Now, I had the slave cylinder out of the tranny, and my buddy (like an idiot) hops in the car and depresses the clutch pedal. The rubber boot and everything slid off that little rod in the slave, and fluid started leaking out. I put it back together, as best as I could, bolted it back to the tranny, and now its likes theres a bunch of air in the lines.
I read that this is a "self bleeding" system, so I figured I'd just try and pump the crap out of the pedal for a while. 12 minutes later, my legs couldn't move, so I gave up.
The fluid level in the resevoir doesn't even drop. I pulled the line off the back of the slave cylinder, and fluid started pouring out again. Does anyone have any idea what the hell I did/am doing wrong?
