What is the biggest high imped Injector?
Just wondering what the biggest stock pcm compatible injector is now? I thought I heard someone had some 96's working? Or is 79's still it?
I used to see Venom advertise an 83, but I never heard good things about them. The biggest I've seen actually in use are the ones I have: 750cc/min or ~72 lb/hr from RC Engineering. Working great, no problem with idle tuning at all.
Oh and the 72lb/hr is at a rated 43.5 psi, so at 56psi they would be more like 75 or 76lb/hr, maybe a tad more.
Jim
Jim
they are at 4 bar and will work with your stock pcm
or you can use the lucas disc 75 that some guys sell as 79's these are rated at 3 bar. At 4 bar they flow about 83 also. These are unmodified
http://fuelinjectorconnection.com/sh...&productId=161
