Any 85mm or 90mm LS6 intake dyno graphs? (I searched)
Old 10-27-2008, 09:38 AM
LS1-450's Avatar
Default Any 85mm or 90mm LS6 intake dyno graphs? (I searched)
Am going to put an LS2 90mm inlet onto an LS6 intake manifold & am looking for any dyno information documented after opening the LS6 intake inlet. Searched under many different words that may have been related to the subject & found nothing. Any information will be helpful. Thank-you
Am changing from my 85mm ported aluminum Weiand to the LS6 solely to reduce front end weight & don't want to lose any power in the process. The car is also corner weight balanced. I have tuning software & have documented pressure & airflow through the Weiand & will be able to compare this information to the 90mm LS6 set-up. Please no "why not a FAST" suggestions.
Have read many tuner statements that suggest that the limited LS6 inlet size causes more of a restriction than the runner. Any dyno information will be greatly appreciated. Thank-you
Old 10-27-2008, 10:26 AM
allngn_c5's Avatar
Good luck man, it sounds like you are stepping into uncharted territory. Again good luck and it will be interesting to see your results.
Old 10-27-2008, 10:34 AM
massls1guy's Avatar
TPIS does this mod to LS6 intakes:
http://www.tpis.com/index.php?module...ed+LS6+Intakes
They also post results for a number of intakes. I would like to see more results from users with different head & cam combos:
http://www.tpis.com/index.php?module=2_17_06
Old 10-27-2008, 11:17 AM
LS1-450's Avatar
[QUOTE=massls1guy;10368695]TPIS does this mod to LS6 intakes: They also post results for a number of intakes. I would like to see more results from users with different head & cam combos:[QUOTE]
Thanks for the links. It looks like I wont lose anything & may actually gain a few, as a result of the swap. It may be a while, but, I will post a comparison in airflow & pressure between the two set-ups. Will include all engine mods & other important information.
Old 10-27-2008, 06:11 PM
crimsonwarrior's Avatar
there is a thread in the southern section were a guy installed the tpis 90mm ls6 intake and gained 18 rwhp. he didnt mention how much torque he gained, but im sure it was a descent amount. His mods were a mid size cam and all bolt-ons. The thread is only a few weeks old you may be able to dig it up
Old 10-28-2008, 11:29 AM
found the thread for you if you couldn't find https://ls1tech.com/forums/showthrea...ht=tpis+intake
Old 10-29-2008, 05:41 AM
LS1-450's Avatar
Thanks for the link.
Quick Reply: Any 85mm or 90mm LS6 intake dyno graphs? (I searched)
