BIG Turbo
Old 10-27-2008, 05:33 PM
71ANTICARB's Avatar
Question BIG Turbo
Hey guys I recently came into pocession of a turbo off of a Cummins ISL (8.9L) it a Holeset but I'm not sure of the model. I was thinking bout using this on my Chevelle conversion, but I know its a pretty big turbo. I am just not sure if an LS1 will be able to spool it up. I know that on the Cummins they are doing upwards of 40psi of boost at around 2200rpm. I thought that at bout half the size that the increase in rpms might compinsate.
Any input would be much apperiacated.
Thanks
Old 10-27-2008, 08:32 PM
97BlackLT1TA's Avatar
Just through some quick research I think you might be looking at a Holset HE400 if it is a VG turbo.
Here is a site I found with a little bit more info.
Old 10-27-2008, 08:49 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
^ You forgot your link.
Post a picture of it and we can probably help you out some.
Old 10-27-2008, 09:02 PM
71ANTICARB's Avatar
Yeah you forgot your link, but its not a VG turbo. I was more wondering if anyone had any input on if its too big.
Old 10-27-2008, 09:09 PM
Grr
Grr's Avatar
get some measurements, or this thread is pretty worthless
Old 10-27-2008, 09:15 PM
http://www.globalsourcingguide.com/D...008/WW/519.pdf
lol sorry
Anyway all holset turbos have a tag on them with the model number on it. Let us know what it is.
Old 10-27-2008, 09:19 PM
Bird-Of-Prey's Avatar
Guys on turbomustangs.com or the theturboforums.com seem to have alot of info on those turbos.
Old 10-27-2008, 09:28 PM
71ANTICARB's Avatar
Thanks for the help. I will get some measurements in the morning and post em up tomorrow afternoon.
Old 10-28-2008, 11:48 AM
lt170chevelle's Avatar
you shouldnt have a problem spooling it. really all depends on your setup. i didnt see what motor you are planning on running.just put a boost friendly cam in there and a stall and you should be fine.
Old 10-28-2008, 06:46 PM
71ANTICARB's Avatar
Hey I found the tag on the turbo, it is a hx40w. It was hiding under a Cummins sticker. It has a 4" inlet and a 4" outlet. I have done just a little reading about them and they seem to be at least somewhat common on RX7s and Buttstangs, so I think that it will work fine on the LS1.
Old 10-28-2008, 06:57 PM
WS6HUMMER's Avatar
I have a Cummins 8.3L (500ci) @ work and the Holset turbo on that thing looks smaller than the 76 I have on my car.
Quick Reply: BIG Turbo
