Dyno Guesses & Bench Racing Forum - A few questions.
View Full Version : A few questions.
1sikws6
10-27-2008, 11:31 PM
I own a convertible Ws6 m6 with the following-
Mods- Ford 9" with 4.11s and a spool, PST D/S, Wolfe anti roll sway bar, Madman co. Tq Arm, LCA's, Panhard Rod, shock mounts, squat brackets, UMI SFC's, UMI Tubular K member/A arms Hal Qa1 R series shocks and 275 front springs,Cartek clutch , kooks l/t, true duals, ls6 manifold, lid, greg weld skinnies, summit stars with m/t ET streets.
My questions are:
What should my 1/4 mile times be roughly
What should my 60 foots be roughly
what else do i need to pull the front tires
what rpm should i launch at?
Ive yet taken it to the track.
mad_steve
10-30-2008, 08:24 AM
take it to the track, test it out.. can't give you times, but if the tq arm is set where it's supposed to be, then it should yank the fronts pretty good. SYA Bars? If you have any questions on set-up or suspension tuning, give us a call.
