ok so i know this is a nitrous forum but what gear :) come on in
Old 10-28-2008, 05:25 PM
98mysticZ's Avatar
Default ok so i know this is a nitrous forum but what gear :) come on in
ok so i have a 408 m6 and will be getting a midwest chassis 9inch..... what gears should i get... 3.73, 3.90 hell 3.42s it makes 484/462 n/a so what do yall think i have been known to catch a race or 2 on the highway so
Old 10-28-2008, 05:27 PM
bad6as's Avatar
well do you want to stick with a 26" tire or go to 27 or 28?
whats your shift points
Old 10-28-2008, 06:28 PM
02SS:ZEUS's Avatar
4.11's
Old 10-28-2008, 09:35 PM
98mysticZ's Avatar
yea stick with a 26 tire and i shift about 6600-6800 and i will be pilling it up over 700rw mabye even more
Old 10-28-2008, 09:40 PM
bad6as's Avatar
6800 rpms 4th gear 26" tire with 3.73s you can do 141 in 4th
same set up but with
3.42 154
3.55 148
3.90 135
4.10 128
3.73 sound like it to me
Old 10-28-2008, 09:46 PM
98mysticZ's Avatar
i have 3.73's in my 10bolt and love them.... have had 4.10's and it pulled really well on motor but would lite the tires up but didnt know if i just neede to go back down cause i went up on power... some of the older "hot rod" guys at my shop... ie high 4 sec true 10.5 guys tell me to go back down to like a 3.42.... BUT i still wanted it to pull good on motor so
Old 10-28-2008, 09:50 PM
bad6as's Avatar
i have 3.90s in my car, and on motor il can spin them easy. and one n20 i cant hook no matter what. 4.10s will be that much more of a pita. but if you got to a bigger tire the gear ratio all changes. but the 3.55 or 3.73 i think is ideal for you
Old 10-28-2008, 09:55 PM
98mysticZ's Avatar
cool man thanks thats kinda what i was thinking also
Old 10-28-2008, 09:57 PM
bad6as's Avatar
try it out your self....
http://www.f-body.org/gears/
Old 10-28-2008, 09:59 PM
KeithBerryZ06's Avatar
I got 3.42 and I run 145 mph in the 1/4 with a M6 on 28's
Old 10-28-2008, 10:13 PM
bad6as's Avatar
going threw the traps at 6k?
btw your car
Old 10-28-2008, 10:45 PM
That's what she said...
TheBlurLS1's Avatar
I went from 4.11 to 3.73 in my car with a 408 + N2O. 2nd gear rolls from 40mph on spray are wicked. Car feels like it's going to do a bumper drag lol. The initial hit from the torque won't break them loose as easy in 1st on motor either, but I do run good tires (Hoosier DR's).
I was on the 6800rpm rev limiter at the 1000' in 4th with 4.11's and 315/35/17's. Went through the traps at 127.
I say go 3.73's unless you're wanting to run 28's, then you should think more about it.
Old 10-28-2008, 11:02 PM
98mysticZ's Avatar
sweet thats what i wanted to hear thanks guys
Old 10-29-2008, 12:25 AM
myfast70's Avatar
I've got 3.73's and love them. If I was making the power you've got, I would go with 3.55's first or 3.73's second. You make pretty stout torque and will easily pull the 3.55's.
Old 10-29-2008, 01:10 AM
TheBlurLS1's Avatar
The only real downside about the 3.73's is getting out of the hole at the drag strip. My ET suffers a bit, but I'm not too concerned about running an ET, I want MPH.
When I get a new clutch in, I plan on trying a little more rpm/slip. Getting a 1.6x and maybe being able to spray 1st on 17's would be awesome. The car goes over 50mph in 1st gear, and that's a lot of time to jerk off waiting on the squeeze to come on in 2nd.
Old 10-29-2008, 09:45 AM
98mysticZ's Avatar
yea i think i am leaning towards 3.55's would also alow me to come out the hole on the bottle mabye haha i plan on leaving about 5k with the kit on... and hold on for the best lol
Old 10-29-2008, 03:51 PM
BAKED's Avatar
I have a 3:55 gear for sale. It was in my 9" for less than 3K miles. I switched from a TH 400 to a powerglide and went to 3:90's
It is a Motive Gear, it's the upgraded one that is double lapped and heat treated. When it was in my car it was as quiet as a stock gear. If you are interested I'm only asking $100.00 plus shipping. There is absolutely nothing wrong with it, I just do not have any use for it anymore.
Shoot me a PM if you are interested.
Thanks
