Backfiring, won't idle, misfire...what to check?
Trying to get my car running for the first time here.
Won't start without the throttle depressed.
Pops loud once started if I let off the throttle or go past 3500rpm.
Was popping on driver side, swapped sides with coil packs and it seems the popping switched sides with it.
Tried replacing the coil I thought was bad and it continues.
No codes other than misfire codes, but even those have stopped coming up now even though the engine sounds like it's missing.
Where can I go from here?
I have a full shop and snap on scanner.
