How long does it take to program the ECM
I m wondering how long it takes to program the ECM if you already have the tune made up and you just need to load it to the computer.
The reason i ask is cause my laptop will stay running now for about 45 min maybe more with out being hooked to a charger(tuning software says not to tune hooked to the charger).
approx 90sec for a cal only and 2min for a full flash of the OS. Full flashes are only required if your changing the OS.. Either way, you'll be fine.
Yep, it doesn't take too long at all.
I have the same problem, old battery killing the life of my laptop. My solution......I bought a cheap inverter. Just think of it as insurance.
Losing power while uploading a tune is not fun.
Well what will i need just a quick cal or a full flash? All i am doing is just tuning for my new heads.
Also i was looking in my software last night and i didnt see anything for the EGR system or the AIR system that i could turn off or delete out of the system, where would it be?
LS1TECH Sponsor
Write calibration only on an 02 Z28 would take 22-30 seconds using HP Tuners barring any connection issues.
Write entire on an 02 Z28 would take 1m50s-2m10s using HP Tuners barring any connection issues.
http://www.hptuners.com/help/vcm_edi...menu_write.htm
"Write Calibration Only" is the regular, safest and fastest way to rewrite the VCM. ALWAYS use "Write VCM" when making regular tuning changes.
The "Write Entire" and "Write VIN/Tunerlock/VATS" options are special features to be used by advanced users only.
