cam? for tsp headed 6.0 recommendations
Old 10-29-2008, 11:55 AM
chevboy28's Avatar
Default cam? for tsp headed 6.0 recommendations
i have 6.0 lq9 that i'm building with arp rod bolts and tsp 2.5 5.3 heads. i want a cam that will pull up to 7k but still have plenty of low end torque. anyone with similar combo have any suggestions. anybody know if the t-rex would be good for this combo? i just know it pulls all the way to 7k. anyone? by the way it's gonna see spray too.
Old 10-29-2008, 12:05 PM
jmm98LS1's Avatar
Are you willing to flycut the pistons? I'll be interested to see the responses to this thread, I'm building a 6.0 with the same heads only I'm doing forged rods/pistons so I'll already have 4cc valve reliefs. I'll probably go custom grind with 24x/24x duration and .600-.625" lift.
Old 10-29-2008, 12:27 PM
chevboy28's Avatar
yup plannin on flycutting the pistons
Old 10-29-2008, 02:18 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
If you want something that breath in the 6500+ range and retains nice bottom end and mid-range power, I'd consider our TorquerV3 camshaft. Its aggresive intake lobe helps make great area under the curve, and it's still bi enough to breath up top too! There are handfuls of dyno graphs for this heads/cam combo in the dyno results forum too!
Let me know if I can help with your build!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 10-29-2008, 03:02 PM
chevboy28's Avatar
what are the specs on that cam?
Old 10-29-2008, 03:04 PM
http://www.texas-speed.com/shop/item...d=669&catid=44
__________________
Old 10-29-2008, 03:21 PM
phoenix1987's Avatar
The same as Doug's cam but on a different LSA.
Old 10-29-2008, 04:21 PM
chevboy28's Avatar
i searched in dyno section couldn't find anything about the torquer v3
Old 10-29-2008, 04:49 PM
https://ls1tech.com/forums/dynamometer-results-comparisons/975054-prc-2-5-ls6-heads-torquer-v-3-mods-sig.html
https://ls1tech.com/forums/dynamometer-results-comparisons/959714-prc-5-3-heads-fast-90-90-torquer-v3-forged-tsp-short-block-numbers.html
There's two from the very recent past.
__________________
Old 10-29-2008, 10:29 PM
chevboy28's Avatar
anyone else any suggestions?
Old 10-31-2008, 05:41 PM
chevboy28's Avatar
what duration and lift should i be looking for anyone? ball park?
Old 10-31-2008, 06:46 PM
5_02ls1's Avatar
basicly your gonna want a cam with a big split...and a wide lsa...the cam i had in my last setup worked this way and it had a 10* split on a 114 was speced for nitrous but worked great n/a
Old 10-31-2008, 06:48 PM
5_02ls1's Avatar
Default duration
id say upper s30s intake lower 240s exhaust
Old 11-02-2008, 10:57 AM
chevboy28's Avatar
thanks
Old 11-02-2008, 01:09 PM
MrElectric03's Avatar
Your best bet is to talk to PatrickG and have hime spec you a cam...it will cost you a few dollars over an off the shelf cam but you will get the results you want.
I had im spec my cam and it made great power for a small cam and runs great!
Old 11-04-2008, 05:02 PM
chevboy28's Avatar
oh and by the way it's gonna be at 12.5.1 and run on corn i know i need bigger injectors for corn should i base the cam around corn as well?
Old 11-05-2008, 08:45 PM
chevboy28's Avatar
so far i'm lookin at the torquer 3, polluter and tsunami which will have the most low end and still have plenty up top?
Old 11-06-2008, 04:11 PM
Torquer will most down low. **** that Polluter turd, get the Trex its proven!
Old 11-07-2008, 05:26 PM
chevboy28's Avatar
yeah but pretty sure the trex doesn't have that much down low it's mostly top end
Old 11-07-2008, 06:37 PM
A cam that makes power till 7k isnt going to have a monster low end. Out of the cams you suggested id say look into the Tsunami, im curious of it myself but havent seen any track times from it. The torquer is also a good cam and will be the best low end of the three.
