Dyno Guesses & Bench Racing Forum - what will she run???
meangreenchevy
10-29-2008, 12:37 PM
got a stock 97 ss with 120xxx its an m6 want to know roughly what she will do... also how do you guys launch these cars im hearing alot of different storys..
meangreenchevy
10-29-2008, 03:15 PM
anyone?
z28rob18
10-29-2008, 03:27 PM
my car ran 13.8 stock at atco
pat-ls101
10-29-2008, 03:51 PM
maybe high 13's low 14's w/ traction w/o traction high 14's
lt1z28camaro
10-29-2008, 04:23 PM
Get staged then pull clutch to where you feel it start to engage, give it a little rpm, then slip it out. IMO thats best way of launching stock 10 bolt to try to keep it alive. (you'll find your own method once you make a couple runs) If you're not worried about the 10 bolt, give it some gas and drop it with some nice sticky tires.
Low 14's I'd guess, unless you get a pretty clean run you may break into the 13's.
meangreenchevy
10-29-2008, 05:41 PM
what do you mean by "slip it out"
lt1z28camaro
10-29-2008, 11:20 PM
When you have it at it's engaging point wait til last yellow then basically get out of the clutch asap then floor it with all motor. But ride clutch a bit to get out of the hole so it's not a shock to the rear. Hard for me to explain it... Just take it out in the country and practic your launching, sounds dumb but I did it in the old car and helped out my launching a lot.
meangreenchevy
10-30-2008, 02:40 PM
thanks man i need to get on that
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
