Ron@Vengeance
10-29-2008, 07:11 PM
Got a pretty interesting build we started Monday and I thought it would be cool to document the build process. This is going to be quite a combo when its all said and done.
Customer Car- 2007 C6 A6 ( 6000 miles!!!!)
Goal-1000RWHP THRU AN A6 Transmission/Stock ECU
Parts List:
Vengeance Racing 402 LSX Low Compression Shortblock- LSX Block/Callies Crank/Callies Rods/Wiseco Dished Pistons/Coated Main/Rod Bearings/ARP Top To Bottom
TrickFlow 235cc CNC 6 Bolt/Cylinder Heads-.650 Lift Spring Upgrade- 160@1.800 (Upgrade-160@1.800) and 450@1.200 /2.080 Intake Valves/1.600 Inconel Exhaust Valves
Vengeance Racing Custom Turbo Camshaft- 23x/23x .6xx/.6xx 1xx+x :)
ARP Head Stud Kit for 18 bolt combo/Cometic Gaskets/Comp Lifters/Melling Oil Pump/ Severe Duty Timing Set/FAST 92mm Ported by Vengeance/SFI Pulley
TTi Twin Turbo Kit with Upgraded Turbos(Supports OVER 1000HP)/Custom Coating
Dallas Performance 1800HP Capable Brushless Fuel System
Blitz SBC-I Boost Controller
Dallas Performance Alky Control Kit-Stainless Line Upgrade
Dewitt Hi Capacity Radiator with built in cooler
ABear Motorsports Custom Enclosed Coil Covers
Yank Custom Converter for A6/TTi Setup
B&B Fusion Catback Exhaust
Pfadt Racing Coilovers/Silicone Hose Kit/Solid Engine Mounts
RPM Transmissions Fully Built 6L80E/1800HP CV Shafts/Prop Shaft/Stage IV Diff with Hardened Output Shafts/SFI BellHousing/SFI FlexPlate
Autometer Phantom Boost/Fuel Pressure Gauges
Innovate LM1 WideBand
VersaFueler Converter box with 95lb/hr Low Impedance Injectors
MUCH MUCH More I will add as the build progresses!!!!
Pics of Progress so far:
LSX with TTi Manifolds checking for clearance.... Problem one found already. Turbo Hits Outer Bolt on Cylinder head/block.... Had to Machine Cylinder head slightly for clearance...
http://i88.photobucket.com/albums/k176/VengeanceRacing/DSC03664.jpg
TTi Turbo/Manifold Assembled
http://i88.photobucket.com/albums/k176/VengeanceRacing/DSC03674.jpg
Customer Car beginning disassembly
http://i88.photobucket.com/albums/k176/VengeanceRacing/DSC03646.jpg
Drivetrain is out of the car....
http://i88.photobucket.com/albums/k176/VengeanceRacing/DSC03650.jpg
Lil Red Corvette with no heartbeat safely in the air...
http://i88.photobucket.com/albums/k176/VengeanceRacing/DSC03652.jpg
Empty Cradles :)
http://i88.photobucket.com/albums/k176/VengeanceRacing/DSC03672.jpg
We just finished up Mounting the Intercooler and trimming associated pieces to get front fascia re-installed. More pics coming soon. Stay Tuned!!!!
10/30/08
Intercooler installed after some minor fabrication...
http://i88.photobucket.com/albums/k176/VengeanceRacing/DSC03695.jpg
Front Fascia Installed with intercooler...
http://i88.photobucket.com/albums/k176/VengeanceRacing/DSC03696.jpg
Intercooler from inside the Engine Bay...
http://i88.photobucket.com/albums/k176/VengeanceRacing/DSC03697.jpg
DeWitt Radiator/C6 Fan Installed.. It actually fits with the Intercooler :D :D
http://i88.photobucket.com/albums/k176/VengeanceRacing/DSC03715.jpg
Minor trimming required for Turbo Piping later down the road....
http://i88.photobucket.com/albums/k176/VengeanceRacing/DSC03716.jpg
More to come!!!
UPDATE 11/5/08!!!!
Engine Assembly :)
LSX 402 Shortblock built a few weeks ago ready to go
http://i88.photobucket.com/albums/k176/VengeanceRacing/DSC03735.jpg
Cometics drying after being coated with copper spray to reduce the change of leakage
http://i88.photobucket.com/albums/k176/VengeanceRacing/DSC03778.jpg
Prepping the deck surface for the head gaskets
http://i88.photobucket.com/albums/k176/VengeanceRacing/DSC03787.jpg
Ready for TFS 235s
http://i88.photobucket.com/albums/k176/VengeanceRacing/DSC03790.jpg
Two be continued below... 20 images per thread....
Parts List:
Empty Cradles :)
10/30/08
More to come!!!
UPDATE 11/5/08!!!!
Engine Assembly :)
Ready for TFS 235s
