Clean ride, 69 Camaro w/ LS1
This is engine bay is done so well. Interior needs some improvement but I'm very impressed with the engine presentation: http://cgi.ebay.com/ebaymotors/ws/eB...;category=6161
Re: Clean ride, 69 Camaro w/ LS1
The engine bay looks great, the exterior is nothing special... kinda bland and leaves some to be desired, and the interior is hidious.
Hugger is always cool though
Anyone going 4x4'ing????? The interior does look pretty crappy. The paint doesn't even look all that great. Nice that there is an LS1 in it already though. Wish I could just take the drive train and drop it in my 68. That would kick ***. Hey Tony, just curious how much $$ does a conversion like that cost?
LS1Tech Co-Founder
used LS1 $1000-2000
harness $400
used PCM $200
headers $700
engine mounts $200
misc engine accessories, etc... $600
that would be a good start. Converting to a T56 or A4 would add more money, but the TH350 will bolt right up to the LS1 and be the cheap alternative.
Tony
harness $400
used PCM $200
headers $700
engine mounts $200
Tony
used LS1 $1000-2000
harness $400
used PCM $200
headers $700
engine mounts $200
Tony
harness $400
used PCM $200
headers $700
engine mounts $200
Tony
Awesome,
Jon
used LS1 $1000-2000
harness $400
used PCM $200
headers $700
engine mounts $200
Tony
harness $400
used PCM $200
headers $700
engine mounts $200
Tony
I wonder if a LS1 would bolt to a 700R4??? I have questions, I need an expert
Then again, seems like a LOT of work just to get piston slap
<-- so tempted....
LS1Tech Co-Founder
LS1EDIT would only be required. The Painless harness doesn't come with all that smog crap on it. You can disable all that with LS1EDIT. S&P makes shorty headers that clear the factory steering box. I went with longtubes and an LS1 rack/pinion instead.
Current progress on my '69:
-1969 12-bolt has been sandblasted, cleaned, and painted with POR15. Ready to reassemble.
-Subframe is at the powdercoater. Should be done this week. Madman is assembling the front suspension and already modified the subframe to fit the LS1 steering rack setup.
-Still waiting on supercharger (next week?)
-Forged interal 348ci LS6 and Stage 2 LS6 heads sitting in my garage. Still have to finish assembly of the longblock.
Basically, alot of work to do. I won't make it by the Bristol Bash on October 18, not enough time. Been busy with work.
Tony
Tony
The worst thing I saw about the car was the seats. Other than that I see a plain Jane 69 camaro with a REALLY nice ls1 conversion.
Josh S.
Josh S.
