hey guys i need some help!!
Old 10-29-2008, 10:52 PM
jrenfrew0606's Avatar
Default hey guys i need some help!!
ok well i dont no how to explain this but the driverside front wheel sits back about 1.5 in farther than the pas. side does any one no what could cause this?
Old 10-29-2008, 10:54 PM
ae13291's Avatar
caster adjustment
Old 10-29-2008, 10:56 PM
jsteele90's Avatar
bent control arm
Old 10-29-2008, 11:25 PM
ok well i was thinking it was a bent control arm to but the car still drives straight and dosent pull to either side but if it is the caster how do you adj that ?
Old 10-29-2008, 11:35 PM
ae13291's Avatar
it must be done at an alignment shop, they use spacers to move the control arm forward or to the back
Old 10-29-2008, 11:44 PM
well the car has been wrecked on that side so i guess it would be safe to say it might be bent. should i take it to have it checked out before i go buy new ones and could they tell me if it is bent
Old 10-30-2008, 12:11 AM
ae13291's Avatar
yes the alignment shop will know if its bent or not, because they wont be able to align the car with a bent arm
Old 10-30-2008, 09:16 PM
ok thanks for the info!
Quick Reply: hey guys i need some help!!
