what is a good use for this cam?
Old 10-30-2008, 01:30 AM
bigjakester's Avatar
Default what is a good use for this cam?
I got a cam with the SS I just bought and I have no idea what kind of cam it is but I do have some specs. The numbers on the back of the cam are 3722R/3671R Hr113 A4501. the number 2871 E is also stamped on the cam. There wasnt a cam card with the cam but there was a piece of paper with some specs on it, 224/221 581-566/113. What is a good application for this cam, n/a, boost, nitrous? And what kind of power could I expect out of it? Thanks for any help in advance.
Old 10-30-2008, 11:41 AM
Raise's Avatar
Usually a forced induction application will favor a traditional split, not a reverse split. The longer exhaust duration lets more air out to compensate for the large amount of air coming in via the FI source. The cam you have sounds like a nice n/a cam for the street. Throw some nice ported 5.3 heads on there to bump up your compression and get the most out of the cam.
Quick Reply: what is a good use for this cam?
