How high so you spin your LT1?
Old 10-30-2008, 11:08 AM
k0261886's Avatar
Default How high so you spin your LT1?
I have heard that these motors don't like to spin high rpms and I was wondering what you guys usually shift at? What do you consider safe? Personally, I shift at 5k on the stock tach., which in reality is like 4700, but I shift there because I don't feel it makes any power after there.
Old 10-30-2008, 11:20 AM
camar0corey's Avatar
I shifted the stocker around 5400-5600. I'd guess 5400 would be showing on the autometer and yeah the stock tach would be reading around 5600.
With the stock motor I had 1.6 RR and some comp springs, full exhaust, 4.10's etc. I got a dyno sheet here showing the thing still making decent power all the way bounced off the limiter.
I don't think it should feel like power is dropping off at 4700, in my case I occasionally hit the limiter if I ignored the shift light cause as the dyno showed me, it was still pulling good. You may have issues if it feel like its dying off at 4700? Not sure.
Old 10-30-2008, 11:28 AM
BlackTA96's Avatar
I shift mine around 6500
Old 10-30-2008, 11:36 AM
z28rob18's Avatar
5500 after that it feels lik it starts to loose power
Old 10-30-2008, 11:40 AM
Tony Shepherd's Avatar
8,000 rpms here
Old 10-30-2008, 11:52 AM
k0261886's Avatar
^LMAO, dang.
I think that it is more of the fact that I am afraid of the motor cause I thought that they were very weak and I didn't want to spin it too high.
EDIT: What is the stock rev limiter?
Old 10-30-2008, 11:58 AM
ABA383's Avatar
63-6500 here...
--Alan
Old 10-30-2008, 12:04 PM
BOLO's Avatar
Mine is set @6800rpm
Old 10-30-2008, 12:08 PM
383lt1impala's Avatar
5500 stock
6000rpm now.
19mike84's Avatar
5700-5900 here. my car seems to make power there. thats usually where i pull on people the most
Old 10-30-2008, 12:12 PM
sn8ke eatr's Avatar
stock- 6000
now- 6700
Old 10-30-2008, 02:15 PM
tscheu5452's Avatar
About 6500 when stock. Damn near 7000 now.
Old 10-30-2008, 02:22 PM
HoLLo's Avatar
Ive been shifting mine right about when the tach says 6000.. 6200 sometimes. stock bottom end
Old 10-30-2008, 02:30 PM
wrd1972's Avatar
6400 here
Old 10-30-2008, 02:31 PM
LS1 SPEED's Avatar
stock short went though the traps at 7000 rpm and had 80K on the clock + spray
new motor is shifting @ 7000 rpm
Old 10-30-2008, 02:39 PM
wrd1972's Avatar
Clearly the exception and not the rule IMHO.
Old 10-30-2008, 02:54 PM
LM97Z's Avatar
59-6000 on the tach seems to make the most power & best ET for mine, 54-5500 it'll loose a good .2 tenths, this is with bolt-ons only, stock rockers too.
Old 10-30-2008, 03:05 PM
DAO95LT1's Avatar
Usually shift at 6000-6100 but goes through the traps at 6400-6500 on a 95,000 stock bottom end.
Old 10-30-2008, 03:22 PM
borninatransam's Avatar
New motor has seen about 7200 and no problems yet.
Old 10-30-2008, 03:25 PM
supernaturalta's Avatar
Limiter is set at 6500 rpm on the stock short block.
I shift at about 6200-6300 rpm.
Quick Reply: How high so you spin your LT1?
