5.3L heads and pushrods question
Old 10-30-2008, 08:39 PM
COJO_24's Avatar
Default 5.3L heads and pushrods question
I have some 5.3L heads (862 casting) and wondering if i need some shorter pushrods? Like 7.375" or 7.35"
I have OEM gaskets, rockers, etc....
Thanks in advance for the help
Old 10-30-2008, 09:08 PM
Raise's Avatar
7.4s will work fine, especially if the heads are unmilled and you are running stock thickness gaskets. I would go with 7.35s if I were you though...just to keep correct geometry
Old 10-30-2008, 09:12 PM
COJO_24's Avatar
Ok well im going to be doing a cam swap very soon and needed to know
somehow while i was changing head gaskets though i bent a pushrod....it was already slightly bent and when i turned the motor over with a wrench to get a piston to TDC it bent it even more. So i will have to get new pushrods anyway....still kind of weird though
Quick Reply: 5.3L heads and pushrods question
