Got a TH400 with brake....how to launch?
I'm new to the transbrake thing, so how do I launch this thing? Just stand on it or am I looking to leave at a certain RPM? Would a 2 step be super beneficial to me? Is it harder on the motor to use a 2 step? It sure sounds violent, but cool as hell too.
1. put trans in 1st gear and press trans brake button
2. floor car, release trans brake at desired boost/rpm
3. ???
4. PROFIT!!
if you street drive it's wise to put the button on a switch to prevent accidental activation. Don't ever touch the button wile you are moving.
3. ???
4. PROFIT!!
I know that much, but thanks.
I guess what I'm wondering is if I should use a 2 step or if just bringing it up on the convertor is enough? Like I have a 4000 stall: Do I want to just stand on it, reving to 4000-ish, and launch? Or do I still need the "flash" of the convertor to get things going? Say if I use a 2 step at 2500 RPM, I stand on it, motor sits at 2500, release and it launched and flashes the convertor to lets say 5000-ish.
Hope that made sense.
LS1Tech Co-Founder
4000 rpms is nothing for that combo Sam, just run it like that and get a 2 step to mess with for later. You are heavier and don't make as much power as kevin did so based on your mph of 139 best you can leave at 4000 and hopefully hit 9.8@142 or something like that.
i found a /b/tard
