Questin about maf and map sensors.
Ive been trying to search, got a few little helpful insights. But do you need to run the maf if you are just running a map sensor? Do you need to run certain ecu setup if you are only running a map?
Thanks in advance.
Thanks in advance.
Moderator
Search "speed density". Custom OS or force a fault
manually and live in a "fallback mode" with some
less-than-desirable side effects (esp. for A4 cars).
At least for GM; know nothing about turbo Hondas.
This is an m6 car. And Im not refering to honda's lol.
This car is going to have some boost added to it thats why Im curious about the map sensor tuning. I dont want to put a maf in the middle of my charge piping.
