396 LT1 Stroker Questions
K i was just wonderin what size pushrods, were used with your 396's. And possibly even the oil pan, havin trouble deciding which one to go with... Fuel Injectors, not sure to go with 36-42 Lbs, appreciate it guys.
make sure if you install an aftermarket pan which has a crank scraper that you notch it so your dipstick doesn't hit it https://ls1tech.com/forums/lt1-lt4-modifications/1010757-someone-please-measure-dipstick.html
Always measure your pushrod requirements with a length checker.
Depending on your gasket and valve selection, head mill, block deck, cam, rockers and lifters, you may need something drastically longer or shorter.
Fuel injectors need to be big enough to handle your HP output at high RPM.
36 are large enough for most N/A stoker builds, 42s are good insurance and leave room to grow.
