¿ Is is Necessary to change timing set to use cc306 on stock motor ?
theres not much too it , all you got to do it pull the crank sproket , a new gm timing chain/gear are not too much $, do it
or upgrade to a gm hd or double
LS1TECH Sponsor
If you are on a tight budget, AT LEAST get a new timing chain and reuse your stock gears. The gears will not show wear but the chain will stretch, have slack, retard the cam timing waisting power and as metioned, have a better chace of breaking and destrying parts.
Lloyd
Lloyd
