new best on hsw 100shot plate kit
I went and ran the 1320x today it was hot. Da hit 3k when the gates opened at 8am. By the time I got my first run off the da was over 3650 and climbed up well over 4k. My first run was a new best
60'.......1.688
330......4.782
1/8......7.401
mph.....92.938
1000....9.612
1/4......11.592
mph.....117.631
Next run was over a 4k da on a half empty bottle (I had to bleed half the bottle down to drop the pressure it spiked to 1250 sitting in the car). Anyway went 11.71@115.6
Then I got word that I had enough votes and made it into the manufactuers cup which will be on tv. By the time I ran the da was back down to the 3600 area. I figured gotta go all out for tv so moved my window switch down to activate at 2200 rpms. So I get up for the first round and dial in at 11.55 and ran this slip
60'......1.618
330.....4.732
1/8.....7.340
mph....93.683
1000...9.534
1/4.....11.496
mph...118.819
I finally hit my goal and ended up winning due to a redlight in the other lane. I made it to the top eight and then driver error took place lifted half track and ran a 12.70@86 mph. No video proof of the run yet but stay tuned for 1320x @speedworld dragstrip
launch sequence
Mods are
3k stall, lt's, true duals, lid, hand port t/b, lca, hsw 100 shot, and a tire
60'.......1.688
330......4.782
1/8......7.401
mph.....92.938
1000....9.612
1/4......11.592
mph.....117.631
60'......1.618
330.....4.732
1/8.....7.340
mph....93.683
1000...9.534
1/4.....11.496
mph...118.819
launch sequence
Mods are
even so if you bogg it would puddle up and go boom on the top end. I thought it was a rule of thumb for all cars to have it at 3k or higher. Or can you set it lower and not have any of the side effects that the M6 cars get?
I'll let someone explain it better who is more knowledgeable about autos. I just do as I'm told still learning about auto's. My friends ls1 camaro sprays it at 2200 also, friends mach auto sprays at 2000, and friends old z28 used to spray at 2400 (200 shot). Basically when the spray hits its flashing the converter up and letting it unload. I've never bogged my car or came even close car just rolls out of the hole nicely as shown above
Ruckus46gt, are you running on a stock 10 bolt rear-end and stall.
The reason I ask, I have an A4 with a 125 shot, bone stock car. On reg. street tires I'm running 12.03 @118mph with a 2.16 60'ft. I have been looking to run a set of DR's to get the 60' time down in the 1.90's in hope of a 11 secound ET but hear horror story of stock LS1's popping the rear-end under stock HP with sticky tires.
