Which clutch disc. Mcleod/Centerforce
Old 11-02-2008, 01:37 PM
LM97Z's Avatar
Default Which clutch disc. Mcleod/Centerforce
I'm useing a stock reman. flywheel & aftermarket PP (LT4), i was told about these too discs., well theres 3, but the 1 Mcleod is a substitute. I've also heard of the Ram 300 series Part# 320-M thats 200.99, i think its also Organic.
Mcleod 261171 Organic (sub)
Mcleod 261871 Aluminum/Kevlar
Centerforce 381039 Organic
http://store.summitracing.com/partde...5&autoview=sku
Old 11-02-2008, 02:27 PM
1996camaross's Avatar
Centerforce
Old 11-02-2008, 06:19 PM
multmigs's Avatar
I'm clutch shopping also, stockish motor Hotcam, LT, etc... whats the benefit of this type of setup vs say just using a RAM HD clutch?>
Old 11-02-2008, 10:38 PM
8 Second 6 Speed Director
taner's Avatar
Location: windsor, ont. canada - Home of the fastest LT1 6spd.
mcleod is the only clutch i have used over the last 7 years, and have tried CF ....plain garbage! lots of issues with it.
just my .02
g'luck on choice.
Old 11-02-2008, 10:52 PM
Biggin'89's Avatar
how much power will they hold with a stock pp? and how do they drive compared to say my spec 3?
Old 11-02-2008, 11:55 PM
LM97Z's Avatar
I've decided to stay away from any puck style disc., i'll be ordering the Mcleod organic in the morning, its 181.99, i like the looks of it.
Old 11-03-2008, 12:51 AM
In-Zane Moderator
ZONES89RS's Avatar
I have installed a dual friction in my 95, when it is running i can give you a update on how well it works, the pressure plate is identical to the one that i pulled, both say valeo and same numbers, but the centerforce has the weights that apply more pressure at high RPM.
Old 11-03-2008, 12:55 AM
jarretthise's Avatar
mcleod is good stuff!! nice choice
Old 11-03-2008, 04:22 AM
Revelation Z28's Avatar
i have a DFX and it sucks. chatters like hell when its hot.
Old 11-03-2008, 06:41 AM
SnakeOiler's Avatar
The first one on your list, should be fine for you.
Old 11-03-2008, 10:32 AM
LM97Z's Avatar
Jegs is not charging me to send the Hays disc. back (sending me a call tag), plus there not charging me to ship the new disc., BUT the only drawback is they didn't have the Mcleod 261171 in stock, takes about 3 weeks to get, they did have the Centerforce 381039 in stock, so i ordered that one, hopefully it'll be fine for what i'm doing.
Quick Reply: Which clutch disc. Mcleod/Centerforce
