Who all have deleted the power steering cooler?
Old 11-02-2008, 04:38 PM
WS6HUMMER's Avatar
Default Who all have deleted the power steering cooler?
I have searched around and cant really find anything. Is the power steering cooler nesscesary?
Old 11-02-2008, 04:41 PM
*98TransAm*'s Avatar
i would also like to know.
Old 11-02-2008, 04:42 PM
ls2 bait's Avatar
i took mine off. its not big deal.
Old 11-02-2008, 05:49 PM
theblur98ss's Avatar
Took mine off as well. I think only SS and WS6 have them but I could be wrong. I think it's an option that goes with 275 tire size.
Old 11-02-2008, 06:42 PM
WS6HUMMER's Avatar
Thanks, that solves that then!
Old 11-02-2008, 06:46 PM
CamaroSS19's Avatar
I took mine of after it blew up and I was getting coolent in the PS pump .
I origanily just tapped the two lines aorund into each other with a barb fitting . But I just cleaned it up and ran the return stright to the rack . It looks a lot cleanner now
Old 11-02-2008, 06:52 PM
WS6HUMMER's Avatar
Thanks, I plan on just making a line straight from the rack to the pump too with hydraulic hose & compression fittings.
Old 11-02-2008, 06:59 PM
98Camarod's Avatar
I didn't even know there was a cooler. I thought it was aftermarket. I remember seeing the small lines, but I've never chased them down. You have any pics of it?
Old 11-02-2008, 07:01 PM
Silver_TransAm's Avatar
Dont need it unless you are trying to road race with 4 big grippy tires. Usually the fluid starts to seep out the cap and boil if doing the above without one. You should be fine everyday driving.
Old 11-02-2008, 07:06 PM
WS6HUMMER's Avatar
I didnt snap any pics of it but its a big alluminum peice thats in line with the top radiator hose. It has 2 nipples on the bottom thats an in & out for the power steering return line. I could see it being an option on SS & WS6 cars for having such wide front tires but I dont need it anymore because I spend more time on the 3.5" prostars than I do my 10" ZR1 front wheels.
Old 11-02-2008, 07:48 PM
dschmittie1's Avatar
I ditched mine makes getting to my SDCE tensioner easier. I just ran the line right from the rack to the pump and got a upper rad hose that was for an f body that didn't have a PS cooler only cost like $18 from nappa. gives me a little more room to work
Old 11-02-2008, 08:31 PM
Sluggish's Avatar
They came on z28's also, I am thinking of ditching mine also. Here is a picture of it if someone doesn't know what it is.
Old 11-03-2008, 04:22 AM
98Camarod's Avatar
I definitely don't have that on my car....
Old 11-03-2008, 11:29 AM
BadgeZ28's Avatar
I ran the hoses down into the driver's side frame rail opening and up to a small air cooler behind the driver's side head light assembly. Just eliminating it would have been so much easier
Old 11-03-2008, 12:07 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
I have that on my TA (non WS6) I've also wondered how much I really need it... My front wheels are 10" CCW's so not sure... I don't really road race my car thru the twisties often tho.
Old 11-03-2008, 05:45 PM
MY99TAWS6's Avatar
So taking it out should help to get a bigger rad in the car maybe?
Old 11-03-2008, 08:07 PM
WS6HUMMER's Avatar
I my case just to clean things up a bit and to get the power steering lines away from the crossover & downpipe.
Quick Reply: Who all have deleted the power steering cooler?
