Mickey T's ET street radials
Old 11-02-2008, 08:17 PM
CETAWS6's Avatar
Default Mickey T's ET street radials
I have a stock 10 bolt with 3.73's and suspension work done is subframe connectors, panhard bar, LCAs, and tq arm. Soon, I will get a 3200 stall in my car. So, if I was to get the Mickey T's ET streets, will it hurt my 10 bolt?
Old 11-02-2008, 08:20 PM
cookba's Avatar
it wont hurt it,.....
it will annihilate a 10 bolt after a few runs.
Old 11-02-2008, 08:24 PM
CETAWS6's Avatar
Hmmm....so what will be a good tire to get for me to hook? I'm not too harsh on my ride. I get on it sometimes but I drive it normally to and from work.
Old 11-02-2008, 08:26 PM
DOUBT IT's Avatar
I've run them a couple times without issue, but my 10-bolt is on it's last leg. If one tire was going to kill yours, it'd probably be the MT.
Going out to the track with Nittos Friday, and crossing my fingers.
Whether or not your 10-bolt lasts depends on a couple of things: wheel-hop, power level, launch, and mostly luck.
I've got 320 passes on mine, and know a couple of guys who have more (one over 1000) who are faster than me, but we're on the rare side of things.
Old 11-02-2008, 08:35 PM
CETAWS6's Avatar
Ok cool. I was thinking about Nittos too. My car's A4 and I have suspension work done so it should eliminate wheel hop but I know it's not a full 100% solution to 10 bolts breaking. I'm about to get a rearend cover girdle on it too. Should strengthen rearend a bit. My power level is not as much as some of you guys. Also, I don't launch it all the time.
Old 11-02-2008, 08:40 PM
DOUBT IT's Avatar
Suspension isn't everything. Sometimes crap on the track can make you wheelhop. Just make sure you let out of it if you do.
From what I've seen, those honestly aren't worth the money. You'd be better saving that money up towards a 12-bolt or 9-inch. EVERY rear I've seen with one of those has broken. My upcoming build doesn't include one, and I don't have one now.
I've seen people break them with stock RWHP. I'm only around 335 rwhp myself, not much at all.
Then what's the point of going?
Launch the car hard, if it breaks, it breaks. I still think it's mostly luck of the draw. Important thing is to enjoy it. You didn't get this car to go easy on it. Just kick back some cash to prepare for the inevitable.
Old 11-02-2008, 09:38 PM
CETAWS6's Avatar
I agree with you man. I will see what happens. I read about the 10 bolts breaking at stock power too. I've done the research saying that some do get lucky. Hopefully, I'm one of those lucky guys. As far as getting the Mickey T's or Nittos, it's up in the air because my current tires have plenty tread. I just wanted to see what inputs I get from here.
Old 11-02-2008, 10:12 PM
Jordan S.'s Avatar
You shoudnt break your 10 bolt at that power level. If it does break just consider yourself lucky.
Old 11-02-2008, 11:13 PM
STRETCH'S T/A's Avatar
You should be fine, I use them at the track and have had no issues. I launch my car at 3k and they cut me 1.66 60 ft times all day.
Old 11-02-2008, 11:22 PM
Pontiacerator
RevGTO's Avatar
My 10 bolt outlasted my first set of MT DR's and now I'm into my second. Bolt-on power level. This is flashing my conveter and dead hooking - 1.70-1.85 60' depending on air.
With your stall you will need them. After installing my first stall I gained .25 with Nittos. That shot up to .6 with Mickeys. Consider the discussion done - go out and get a pair.
Old 11-02-2008, 11:30 PM
CETAWS6's Avatar
OK then I should get the Mickey T's when I get to it.
Old 11-02-2008, 11:31 PM
CETAWS6's Avatar
You still got the 10 bolt right?
Old 11-02-2008, 11:50 PM
yeap, the 10 bolt is still alive. One thing that might help destroy the 10 bolt quicker on these tires is if the track is hooking like a ****, not saying this will always break the 10 bolt, but you never know. Saturday at the track, 4 cars went down, they were Cobras and Vettes though.
Old 11-02-2008, 11:51 PM
DYING BREED's Avatar
anything can happen, but i havent had trouble and mods are bout equal to yours and my friend runs them only he has a built trans and a 4k stall and he went 1.54 60 foots running 12.1 at bradenton with no issues... good luck and be prepared
Old 11-03-2008, 05:47 AM
RedsrtAk's Avatar
Depends....some kill it pretty quick....and some last a LONG time.
Mine saw tons of 1.6 60 fts and low 11 to high 10 sec. passes (on MT street Radials) before it finally let go.....I agree with most everyone here.
That is the most legitimate choice for you for optimal traction that will be the softest you can on your 10 bolt.
Old 11-10-2008, 09:29 AM
Banging some gears
greyghost4x4's Avatar
stock 10bolt=
rear end cover will not help in your situation b/c the auto cars aren't as violent on the rear as a six speed. put the MT's on that bish and hope for the best.. if it breaks....
buy a 12 bolt and be done with it. it's hella expensive but worth it in the end.. i'd rather spend 3k once than spend 600 everytime it breaks for the rest of the cars life!
just my .02
Old 11-10-2008, 11:18 AM
TA1364's Avatar
Dont put a bigger converter in the car if you arent going to put sticky tires on to benefit from it. Really 3200 is small and you should be ok. Im on a 10 bolt going high 1.5s 60'.
Old 11-10-2008, 12:47 PM
Camaro396's Avatar
You will be fine. An auto car pre-loads the rear end enough to be easier on it, where as a stick shift car shocks the tires/rear-end/drivetrain a lot harder.
Old 11-10-2008, 01:30 PM
LS1 SPEED's Avatar
it could break at anytime with our without the tire
realistically auto cars do not break them often compared to 6 speed car
We ran a 10 bolt in my fathers 01 Z H/C and N20 and seen many, many mid 1.4 60 ft times and never hurt the rearend. The driveshaft was in a few pieces once
Old 11-10-2008, 01:41 PM
kdavis's Avatar
i have countless passes on mine and i am cutting 1.6 60s. i have used the mt et streets and the et street radials. both good tires. The key is to eliminate wheel hop. i know the 10 bolts are not the best, but i guess i have better luck than most.
