PRC 5.3 2.5 to mill or not?
Old 11-03-2008, 09:38 AM
PewterMNZ's Avatar
Arrow PRC 5.3 2.5 to mill or not?
I have a full bolt on + cam M6 z28. Next step for me is to get the PRC 5.3 2.5 heads. I would like to hear the pro's and con's of milling probably 10mm.
I live in MN, drive it only in the summer, 92 octane is the highest we have in MN.
Old 11-03-2008, 09:51 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
What camshaft are you running?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 11-03-2008, 09:53 AM
PewterMNZ's Avatar
TR230 reverse split.
Old 11-04-2008, 07:34 AM
PewterMNZ's Avatar
TTT anyone?
Old 11-04-2008, 09:11 AM
Did you mean 10mm? Because that's ALOT of milling (about .40")! You should be able to mill those heads about .015" or so without piston to valve clearance issues. That will give a nice little bump in compression which will help your throttle response and mid-range numbers.
I personally would go with a .040" gasket instead of milling. You'll achieve roughly the same compression results, but with a better/tighter quench which helps ward off detonation issues.
__________________
Old 11-04-2008, 09:31 AM
PewterMNZ's Avatar
sorry, yes i meant .010" . So by running a thicker gasket it does the same thing as milling?
Old 11-04-2008, 09:38 AM
Jason 98 TA's Avatar
Typically the thinner gasket is a little bit better than the milling. The good part of milling is it costs way less than Cometic gaskets... We typically like to run the cometic .040" when there's enough room!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 11-04-2008, 04:22 PM
ZMONSTER!'s Avatar
Id go with a thinner gasket. You are someday going to want to run a larger cam, and when you do you dont want to have to worry about getting it flycut, like me...
Old 11-04-2008, 04:47 PM
phoenix1987's Avatar
Wrong.
Old 11-04-2008, 05:09 PM
PewterMNZ's Avatar
Originally Posted by phoenix1987
Wrong.
Sorry Luke, 90% of gas stations have 92, a select few in certain areas have 93, and a few places have 110 ...
Old 11-05-2008, 11:39 AM
Just making sure you knew that you can get over 92 in MN.
Old 11-07-2008, 09:20 PM
PewterMNZ's Avatar
TTT any other opinions on whether to mill or to put a thinner gasket?
Old 11-07-2008, 09:23 PM
ZMONSTER!'s Avatar
Thinner gasket unless you want to stay with a baby cam forever
Old 11-08-2008, 06:38 AM
PewterMNZ's Avatar
Is thinner gasket = less chance of detention correct? I want to make sure they are equal to HP gain. Whatever is going to give me the most HP is what I want to do .
Old 11-08-2008, 06:50 AM
sedanman's Avatar
I wouldn't mill for fear that you can never run a larger camshaft without fly cutting.
Old 11-08-2008, 06:54 AM
firefighter813x's Avatar
Buy the heads already! I want to get a idea how they work with my 230/227 cam.
Old 11-08-2008, 10:35 AM
SOMbitch's Avatar
Run a .040 Cometic. The downside is they ar $150 a set. And use the copper spray even though Cometic won't mention it.
Old 11-08-2008, 03:05 PM
I had the PRC 5.3s with my TR230. Car ran great and was fast! I put a car on a H/C MS3 ls6 intake car when I had a base tune and an ls1 intake. Great combo!
