Is this a good spot for a ground?
In the spare tire well. Is there a way to test whether it's a good ground or something.
Also, does anyone know where I can get these:
I've looked around and can't seem to find them, but I can't hook my tweeters to my crossover with them. It's a 2.8mm male blade connector.
I think the seatbelt bolt is by far the best. I saw one the other day that had ) guage there. I tested it with my multimeter to the floor board and it had perfect continuity. So Seatbelt bolt is good.
Deff make sure you do that. The first stereo I had the amp blew up from having ground then not then it arc'd and burned my connector area up.
oh and bolt it down tight NO MOVEMENT!!!
