Problem running two nozzles with different jets?
I had an extra nozzle and jets laying around (smaller jets than the one I have in my main nozzle) so I bought a couple T's and two more hoses and started using the second nozzle. Eventually I might change it into a two-stage kit, which kinda leads me to another question. With a two-stage kit, do I just T off the main feed line into the two solenoids? Some people had warned me about pressure drops and I wanted to make sure that all is kosher. Thanks
so it's definitely ok to run the system with two nozzles with very different jets (one jetted for 75hp one jetted for 150hp)? i'm trying to diagnose why my system isn't working right and just wondering if that's part of the reason
Seems like the larger I jet it the more inconsistent it gets. I'm going to temporarily switch back to the 75 shot with a single nozzle and see how that works. Then I'll try the 150 shot single nozzle. Maybe the problem really is with the two nozzles jetted so differently.
Guest
Posts: n/a
you need to run both nozzles with the same jets in them....the flow will take the path of least resistance.....you are running a huge jet split with the single nozzle jetting. If you want to run a 200 shot ...put 100HP jetting in each nozzle.
A direct port running a different jet split is not an issue, as the jet splits are not as large.
What are the issues you are having.
