Chevrolet Camaro 1967-2002 - easy fuel pump access
emolineaux
11-03-2008, 02:15 PM
hey guys have any of you cut a hole in the floor on your 4 gen camaros to gain easy access to the fuel pump? if so can you send pics so i can do mine. im not sure where to cut and i dont want a huge hole in my floor. this is for my 98z
AFASTYZFR1
11-14-2008, 07:01 PM
http://i210.photobucket.com/albums/bb201/D-1SC_SOM_SS/IMG_3226.jpg
AFASTYZFR1
11-14-2008, 07:03 PM
I think 98's are a little different but figured I post the pic anyway
EnfuegoZ28
11-15-2008, 03:27 PM
Don't do it! Unless you seal it REALLY well your car will smell like gas. Just unbolt the 2 straps and wiggle the tank out, just make sure the tank has only 1-2 gallons of gas in it.
01ssreda4
11-25-2008, 01:32 AM
caulk isn't expensive. i mean really how hard is it to seal two pieces of metal against atmospheric pressure?:confused:personally i think its a great idea, also considering lots of cars COME with these access panels....
Ntimid8r7
11-25-2008, 07:27 AM
It isn't that easy. If it were more people would do it. Your car will not smell like gas if you make sure the O ring is in place. I have done this on 2 cars and have had 0 issues. You will be the only one who knows the hole is there and you will thank yourself for doing it later! Cutting the hole will take no more than 15-20 minutes at the most compared to trying to drop the tank which in most cases will require the rear to be dropped.
http://i36.photobucket.com/albums/e32/Ntimid8r7/fuelpumpremoval001.jpg
http://i36.photobucket.com/albums/e32/Ntimid8r7/fuelpumpremoval007.jpg
http://i36.photobucket.com/albums/e32/Ntimid8r7/fuelpumpremoval004.jpg
bigjohn450
12-02-2008, 08:29 PM
i just bought my car and my sending unit is bad as well, im just wondering do i have to replace the whole fuel pump? or can i just get a new sending unit? the pump works great just the fuel guage jumps from full to empty all the time which drives me nuts!!
Ntimid8r7
12-04-2008, 10:13 AM
If I am not mistaken you have to buy the whole assembly. You might as well as they will go out when you least expect it. Like the gas station or grocery store. My luck is it never happens at home! :bang:
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
