purge help
Old 11-03-2008, 07:00 PM
snk-huntr's Avatar
Default purge help
I just bought a purge kit for my nitrous works, 100 shot wet kit. Where exactly does it go? Do you put the line from the bottle into the purger and then from the purger to the nitrous sollinoid. The purger has one outlet and two hook-ups on the opposite side. Can someone please help?
Thanks.
Old 11-03-2008, 07:10 PM
SuperSlow02's Avatar
youll put the purge right next to the Nitrous noid. You want as short of a distance as possible between the 2. Mine is a HSW kit, and mine Purge noid is mounted on the Nitrous one.
Old 11-03-2008, 07:20 PM
snk-huntr's Avatar
I've got the purger mounted beside the nosnoid, but how do I run the lines to hook it up?
Old 11-03-2008, 08:11 PM
BAKED's Avatar
Main line to purge noid, purge noid to N20 noid, N20 noid to nozzle or plate.
Old 11-03-2008, 08:12 PM
bad6as's Avatar
btw what size shot you runing
Old 11-03-2008, 09:23 PM
snk-huntr's Avatar
100 shot for now but i have jets for 50 100 and 150 its my first time using it so im alittle sceptical to use a big shot lol.
Old 11-04-2008, 09:33 AM
Nick@HSW's Avatar
Our purge kits come with this fitting: http://www.harrisspeedworks.com/shop...cat=348&page=1 . It goes inline with the main feed line at the solenoid. Just use a 1/8 NPT nipple to connect the two: http://www.harrisspeedworks.com/shop...cat=346&page=1
Here is a pic of one hooked up inline with that fitting.
Nick
