will I have any problems welding this Bullet in place of the stock muffler?
you wont i would suggest to get some cheaper ones from summit they are the same thing, if you are fabbing it up yourself than might as will go duals because you are going to have to do bends where your old muffler was....
If you want to just have an easy weld/clamp on muffler I recommend a magnaflow single inlet/dual outlet. You need the magnaflow mufler part #12266. This is correct as long as you will be using the STOCK diameter piping
